fan rad mounting
SparkleDJackson
whats crackin dudes. started some assembly of my bits today. my both my phobya gchanger rads didnt come with enough full length (35mm i think) i was peeved off about that, but what im asking about is, im doing push pull but the rads only came with enough rubber dampers for 3 fans. is it ok to mount the other side rigid to the rad or should i order some dampers and more proper length screws. i must say this is the first time ive ever build a computer and i must say its thrilling as flip. just to wait for kepler and sandy bridge e for my rig to be finished
Cheers for the reply. Ive still got about another 8 fans in varying size to order so im just going to order plenty of the correct size that i will need. Cheers again
