Fan cooling on 600T
s.deng94
Hey guys I'm currently using all stock parts in a 600T (white) case and I was thinking of upgrading the fans. I only had a ssd and one mechanical drive and I'm thinking about moving that up to the optical bay area once I find two adapter slot things. I also have a cooler master hyper 212 as a cpu cooler.
I was thinking about changing the top 200mm fan for two corsair static pressure fans. Maybe adding another 120mm fan to the cpu cooling unit. I also want to change the 200mm fan in the front. The case also comes with a fan controller that can control up to four fans. Which should I tweek and which should I keep plugged into the mobo? Any advice and prior experience before I make a decision will be great. Thanks!
Bitfenix spectre pro 200mm will fit in the front but you may need to file off some of the plastic around the area where the front of the case pokes through.
That's pretty much the only 200mm fan worth putting in there. Comes in white too.
If you want them to match you can get 120mm versions for the roof/back, also in white. The 200mm will not fit in the roof. I'm not familiar with the hyper 212, but if you orient it so that the fans blow towards the roof, that's what I'd do. Then I'd have 2x120mm in the roof exhausting, and screw a silverstone 120mm fan filter onto the rear fan and have that as an intake. 1x200mm is not enough intake imo.
That plan may change if you have non-ref gpu cooler and definitely will if you have non-ref cooling SLI/crossfire, as you'd need the exhaust there.
edit, just seen your spec. you may be ok with intake there i guess.. kepler is pretty cool.
If you move the HDD trays bitfenix spectres fit absolutely fine. See my pc (link in sig) I have a 200mm bitfenix spectre pro in the front and a 120mm for the back. Both are white LED versions so provide a bit of better but subtle lighting to my pc too!
oh and on another note, in case you were wondering they work fine with the fan controller
^ did you need to remove any plastic from the fan to mount yours? I may have been hasty with mine.. I guess if I mounted the fan at a different angle it would been fine? Still.. I was adamant that the bitfenis sticker would be the right way round.. lol.
Like I said after moving the hdd cage across I had no problem installing the fan without modifications. I just used the rubber pull through rivets that came with it to install. For intake the bitfenix sticker is facing into the case
