Fan Controllers
mastercrim
I have been searching around for a decent single bay fan control and not having much luck finding one with a lot of power and good reviews. I am looking for something 20-30+ watts with at least 4 channels. I really don’t want to go with a dual bay control unit or I will have to get rid of my dvd burner drive which will not be a big issue cause I never use it and can just plug it in only when needed (or buy external which I would probably do because I get lazy) Not really worried about cost more worried about the specs and if it will power my fans for watercooling. Looks like Aerocool is a pretty common manufacture anyone have anything bad to say about them?
I really like the Lamptron FC5V2 after reading a few reviews. If no one has anymore to recommend I will order this one at payday.
