Congratulations mate, and welcome to OC3D. Unless you can find a controller that will allow you to run 8 fans, let alone control them, then you'll more than likely have to run two rheobus's (fan controllers). There are a number of very good ones available, and it really depends upon your budget and the fans having 3-pin connectors. Check the links I've included for you below:
