Fan controller software
fud
Ok got a Prolimatech Megahalems and got to akasa apache fans set in a push pull set up on it. One fan is plugged into the cpufan slot while the other went into system fan 2 slot.
Annyoing thing is the one connected to the system fan slot does not always come on so i need some software to keep it going all the time.
Tried doing it in the bios but no joy for setting fan speed.
Anyone help?
Thanks Fud
Get a 3 pin to molex converter and run it flat out? Get a fan controller and plug it into that?
I heard good things about Speedfan, but having not used it myself I can't fully recommend it.
checked that speedfan out don't seem to be able to change fan speed. If u can its not very clear.
All sorted now just decided to change the fan to a diffrent power socket that did not regulate speed according to temp. Its going full wack but some nice cooling atleast :)
