Hi, I'm looking for a fan controller that uses the temperature info from the motherboard. That way I can just set up fan curves for each fan when on auto mode.
I want my rad ka for fans to run off of auto mode because, my extra gpu fans to run off of a probe and then my case fans to run off of probes too.
I bought the Bitfenix recon, but it's not really doing what I want. The manual control works fine, the auto just works off the probe temps. This isn't so bad, I'm using the phoebetria software but it doesn't save my auto fan curves after I reboot. So the whole unit may as well just be a manual controller.
Anyone got any ideas?
