ello lads
im stuck with something that is very complex to my eyes
say, a PWM fan controller, with 3x3pin out put@12v max
out put 1 - (fan controller) -> 3pin Y split -> 2x80mm fan
out put 2 - (fan contoller) -> 120mm fan
out put 3 - (fan controller) -> 80mm fan
fan controller Option 1 - Zalman FanMate [Maximum Fan Wattage: 6W]
fan controller Option 2 - Noise Blocker Fanspeed contoller [For ventilator up to 3 watt achievement receptions]
which one would work? or none would work due to power output is a PWM type instead of Analog type......
how many Watts = Volts? a quick look Watts = Volts x Amps......that doesnt mean anything to me
suggestion?
suggestion?
