WYP
News Guru
Fallout 4 system requirements released. Can you run it? Good thing it is much less severe than Battlefront.
Find out Fallout 4's system requirements.
If GTX 550 Ti can run it so should the 7790 if you have a 2Gb version unless they're about to screw over AMD users.I'm gonna cry once more..my 7790 is gonna cry a alot harder tho..
Well i'll be fine if AMD can sort out some crossfire support for it. Given how old the Creation Engine is surely it cant be all that hard to get the drivers crossfire ready before launch?
ahh who am i kidding....
Surprising they look for an Intel i7 or the AMD FX-9590 as the recommended.
Is it going to be quite CPU bound? Probably likely if Skyrim was any indicator.
Dont know skyrim dosent use nuthing on my system even with 60+ mods it just potters on by @ about %15-%30 cpu usage.
I highly doubt it needs a i7 tbh (games dont make use of hyper threading) its just devs being devs
Pretty much every benchmark I've ever seen with Skyrim had the Intel i5s, i7s and even i3 pushing any given graphics card to a high fps rate than any AMD CPU.
Although I played through skyrim like 5+ times with various mods on my last system which had an AMD FX-8350 with no overclock, a GTX 780 (which I still have) and a Radeon 7950 Boost before it.
It always ran quite well, but I remember having to turn down the shadows or some other setting. But generally with that, the frame rate remained locked at 60fps like 90% of the time but every now and again it would drop to the mid 40's. So even if I hadn't the strongest CPU, it didn't prevent me from enjoying the game a lot.
It will actually be damn interesting to see how it does run across different hardware. Bethesda were said to have been taking their time with the release to make sure it was done right.
It's also a game I'm really looking forward to, given previous games you could really get lost in for days/weeks on end.![]()
W
Bethesda did not spend one second of dev time on the engine, deciding to concentrate on content instead.
I hope they did spend some time on the engine ^_^
