riotcity76
Download
http://foldingforum.org/viewtopic.php?f=67&t=18034
http://foldingforum.org/viewtopic.php?f=67&t=18043
* Improved Windows installer with support for Windows XP, Vista, 2008 and Windows 7.
* 64-bit OS-X install package. (32-bit in the works).
* Debian/Ubuntu and RedHat/Fedora/CentOS 32-bit and 64-bit Linux packages.
* Low priority background operation has very little impact on your computers usability. You should hardly notice Folding@home is running when using other applications.
* A more compatible and stable 3D protein viewer with several view modes, rotation, zoom, online help and interpolated protein animations.
* Separate but integrated console client (FAHClient), user interface (FAHControl) and 3D protein viewer (FAHViewer).
* Novice, Advanced & Expert user interface modes. (See drop down list in FAHControl.)
* Support for more than one Folding Slot (UNI, SMP or GPU).
* Ability to monitor, configure and control many remote folding clients from a single computer.
* Very low CPU overhead for FAHClient, FAHControl and FAHViewer. 3D viewer overhead can be minimized by disabling rotating and protein animation.
* Single client for normal (Uniprocessor), SMP (Multiple CPUs) and GPU (Graphics Processors) folding.
I just want to highlight a few common questions that a lot of people will have:
* This is a new client, not new FahCores. With the exception of FahCore_16, you'll still get assignments of the same projects and will earn exactly the same PPD.
* FAHViewer only works with FahCores which produce a current.xyz file, so for most people it will show a demo protein.
* Third party monitoring programs such as HFM and FahMon and FCI have not yet been updated to work with V7.
* If you configure a Windows service in Win7/Vista, GPUs cannot fold. (Limitation by Microsoft).
* New WUs will be downloaded not long before the current WU finishes; That WU will start processing while the previous results are being uploaded.
* A "slot" is a new concept probably best defined by an example. If you have been running several V6 clients on a single OS, you will now be running one FAHClient with several slots.
* You will probably never use a command-line parameters. With FAHControl, you can change your configuration as needed.
* The more complex your installation, the more you'll need to read the documentation.
