eyefinity question
badtaylorx
id like to run eyefinity with my new build and ill prolly just go with 3 27" 1080 monitors.....unless.........ok i know your supposed to run like resolutions...but can irun this
L= 27" 2560x1440 in "landscape"
P= 19" 1440x900 in "portrait" like this PPLPP
is keeping the vertical ammt of pixles equal enough to satisfy the eyefinity gods??? or is it 3 27s for me???
thanx in advance for any help you can provide me
I've never seen it working in person but I'm sure I've seen someone running a setup like that on the web before.
It was something like a widescreen in the middle running 1366x768 and two older monitors running at 1024x768 at the side.
you can do it in one way or another. if its not supported in ccc then just download softTH.
if the 19s are dvi then be sure to factor in 4x dp adapters in the total cost, might not be worth it?
