Eyefinity monitor configuration ?
paulstung
I have asked this question before and already had the answer of NO, but here goes again but with a twist.
I'm thinking about eyefinity but would like to no if it is possible to use a larger monitor in the middle ( 32" 3d tv 1080 ) and either side a 23"/4" either side but in portrait. This is where the NO comes in, and the twist. What if the two outer monitors had the rotate function ? Like the Dell U2412M.
I'm only asking because I used to have my 2nd monitor in landscape beside my 32", but tried it in portrait and it just was nicer to use, and a more pleasant experience. Any way is it possible ?
I don't mean the rotate in ccc, the function some monitors have built in when flipped.
In order for eyefinity to work it needs all monitors to be in the same orientation (landscape or portrait). That is just how eyefinity works, you can't change it.
What you can do is use extended mode, which requires no setup. For games you use them in windowed mode and stretch them or some games support custom resolutions(Just cause 2 f.e.) or use SoftTH for Dx9 games.
