I am tired of hearing fan noise.  my air cooled system is driving me crazy with my 2x gtx 570's (with stock coolers), its freaking loud!
So i have had this idea for some time:
to build an external radiator box with enough heat exchange power to work passively most of the time, and during intense gaming some fans could kick in and cool things down.
As my current case is barely large enough to fit one 240 RAD in the roof i figured instead of upgrading my case (as i have already put a lot of time and effort making my current one look all nice) i would build an external system that could handle future computer builds.
I was thinking to buy 1x 360 rad and mount fans to it, then buy some baseboard radiators and use the copper fin pipe as the passive portion of the radiator
see link:
http://www.finnedtube.com/finning-photo-gallery.aspx
http://www.tex-fin.com/prod.htm
or a car radiator. (much larger for lower cast than a typ 360 RAD)
or a radiator from an old A/C unit (could find junk one for free)
So my question goes out to you,
Is it possible to get enough cooling from a passive system?
would it be worth wile to even build something like this?
all comments and suggestions are welcome,
cheers,
see link:
cheers,
