Exile Build Maybe finally completed ... Maybe
Great work on that build. It's pretty much perfect (almost). I the case modding and the blue liquid cooling. Looks great!
Love the rigid tubing.
Is that a 360 full size rad in the front?
Im wondering in getting the 540, but I have a XSPC RX360 which is 63mm thick, I think, and I'm not 100% sure if it fits with 1 set of fans.
Very good job mate, looks really good.
Thanks.
Honestly man, nice build. I'm sure you worked hard saving up for it as well as actually building it. Patience is rewarding. Two thumbs up.
I've got a question .. What Kind of hoses u use ? Rigid or flex.? Find These straight lines beautiful ��
Hello from Corsair
Yellowbeard here from Corsair. My marketing manager spotted your rig and suggested that I feature it on our forum, blog, and on Facebook. I just wanted to check in and make sure it was cool to repost your pictures.
Great work, this is awesome looking! :cool:
Catch up and replies time
As it say's it is catch up and reply time. As my build is proving popular and a few questions are popping up. I will do what I can to answer them and reply to any relevant feedback when ever I can.
I am wondering in your opinion what is "Almost Perfect" ? Or was it from my title "Maybe Completed ?"
WOW!! i love that!!
quick question, isit me or is the monitor sitting higher than eye level?
The monitor for me sits what I consider/believe to be perfect level for me. My eye line is 1/3 down from the top of the monitor. How ever it is on a rotate and swivel arm as My wife likes to watch some of the shows I watch So I can pull it out for us both to see clearly.
Hey man is it possible to fit a 85mm width res at the spot you fit your's.
Thanks ;)
Personally I would say It would be very close and you would need to consider the closing caps on the res. Most protrude slightly from the actual res width and this is the problem. Also consider its a small case and putting somthing that big in will dominate the case. I tried the XSPC Photon and the Primochill CTR and the XSPC was massive but may of fit with a little working and the Primochill ones felt just a little to big. If you was planning to do a no HDD build you can put the SSD's behind and mount a tube res on the base/floor and that would give you a bit more leeway. This will also allow to keep the fan at the back if wanted.
Thanks.
Its an Alphacool 360 XT45 in the front. Using anything bigger would have caused me problems.Please see the attached Pics.
Thicker Rad will come close to the GPU so please consider this. There is space to move the top rad back a little with no modding. But also possible to take it all the way back with a little drilling and reinforcing. Also think of the layout My fans are on the outside of the mount if you want P/P this is going to add 25/50mm and depending on tubing you will use is also a factor to consider.
Its Primochill Rigid Tubing match with matching fittings. I do not think it is really considered Hose. They only do one size to match the fittings but mate they are a snug fit and really reassuring also in many different colours to match or mix with the fittings. I think there are other manufactures of tubing and fittings that are similar.
Yes mate of course. Anything I left out or you want to know just ask.
Thanks again All for the positive feedback and I hope my rig has inspired some of you to push your own rigs to the next step.
