Evga GTX 570's HD to hot?
TiDew
Hello mates,
I have two Evga 570 HD in SLI. When my system is running in idle i get following temps:
GPU1 - 34°C
GPU2 - 31°C
and when they are running on full load:
GPU1 - 87°C
GPU2 - 79°C
Are they running to hot? I really don't know. Personaly I think they are to hot in full load, so can anyone help me find a solution?
Thanks in advance!
well like said in the other thread which was off its topic its still within operating ranges but I personally like to keep mine under 75c but thats me. did ya try the after burner and et it up for a auto fan profile to ur specs??? I have mine set at like 405 fan speed up to 50c then have it go up by at a angle from there to 80c at 100% fan speed my card never hits above 75c now also keep in mind ur upper card will run a tad warmer as its getting heat from down below
my fans are on max and i still get 88°C.. Maybe the best option is a aftermarket cooler?
--Found the problem
MSI afterburner wasn't working but EVGA Precision works fine..
cool glad its sorted out and unfortunately there are no after market coolers for the hd cards as they are non reference design
