Etlars new build log "Unmaned case / build"
Looks great. A little friendly heads up about airflow. Heat rises so i would turn those two top fans so that they are blowing hot air out instead.
It is done, it was just to show them ;) But i testet the fans that way, and the normal way. 5c in temps going down.. So not that bad :D - Just need learn the way to OC the cpu right ;)
I think it is time to do a small update here, have done a very small modding on my case today. but that was only to give better airflow out of the case in the top.
First picture will show my top mesh whit the linies in it, and nr 2 will show whitout.
It will also maybe make me use the top to get a rad in there. But need to tjek some things first.
So after some test on my ivy cpu, and find have seen i'am so unlucky in that. My cpu will not go lower then 1.232v @ 4.4 mhz. but you cant win all the time, but still like my setup ;)
A small update from my site, this work is not done yet. But the good man James from "Pexon PCs" is doing a very lovely job on some sleeving to me :D
- You can see that i will go full on whit the MSI MPower build, whit the colors :D
So a small text update, there will be case change in my build, going to do a black and Yellow build full out now. And i will like to keep my case "Normal".
But the new case is Corsair - C70, and why that case ? I have seen a build on that case on the forum, but i will do some small things. The Window will be clear and the linie out site the case window will be yellow and the same whit the fans i will use. And the Yellow color i will use is come from the same coler my cable is.
I will thanks "B NEGATIVE and Pexon"
"B Negative" To give some nice and good ideer on the case whit your build in that case, i hope you dont hate me to take some of your ideer on from that build.
"Pexon" I'am so happy on your help on my sleeving, this will make my build just so lovely and good.
And a site note, the build / projekt will be called "Bumblebee" ;)
So to a small update, i was home and was looking on some new menory to my PC. And i found some whit "www.caseking.de", and talk whit my friend on it and then he says, wait to i will be there, maybe i need some items also.
And my friend come whit some thing to me, and says that was my chrismas thing.
What do you say to this ? And yes i'am happy :D
Not at all mate,if you like something then use it.
Thanks mate, maybe i will need some of your help on some infomation later on ;)
So i small update in text, just to say that my build is not die yet :P - But waiting on my last water parts to get home. But her is a list of my items that will come home and also what i have :D
Gpu cooler - XSPC Razoer 7970
Cpu Cooler - XSPC RayStorm
Rads - XSPC RX 240 + EX 240
Pump - Laing/Swiftech MCP655T
Reservoir - XSPC D5 Dual Bay Reservoir
great looking cables! excited to see these in your build.
So have some picture to you all, and that is from James alias Pexon on this forum. I most say that work he have done to my cables, is true art :D
That was all from now, in same days i will post a update whit my water cooling kit i will use :D
