EK-D5 Dual TOP O-Ring
grandpatzer
I have bought a used EK-D5 Dual Top, the seller did not send the O-ring that is necessary to put between the block and D5 pumps.
Question can I put the original O-Ring that comes with the D5 pump between pump and the D5 Dual top?
One of my pumps is a Swiftech 655 original top and the other one is D5 with a EK-D5 X-Top Rev2.
I'm pretty sure that I can't install the EK Dual without the O-rings, anyone have any idea where to get them?
I propably should return the product to seller for a refund....
The D5 X-Top o-ring is the same as the ones used in the Dual-Top. I'm not sure about the stock D5 o-ring tho. If it turns out that the stock o-rings fit (hopefully ek will answer your e-mail quickly) you can find some here:
http://www.specialtech.co.uk/spshop/customer/O-Ring-for-Laing-D5--D5-Variant-Pumps-pid-16541.html
Or you can order on EK's website:
http://www.ekwb.com/shop/pumps-and-...echanisms/mounting-mechanism-d5-dual-top.html
Edit: the o-rings for EK tops are 61x3mm.
yes EK reply me that O-Rings are different :(
So now I have to try return top back to seller for a refund.
I googled O-Ring 61x3mm and did only find 61x3.5mm Oring....
So I guess EK is the only one with 61x3mm O-Rings
