WYP
News Guru
EK have announced their first ever AIO Watercooler. Meet the EK Predator,
Read more on EK's Predator AIO.
Well if this could've been just an AIO for the CPU, then that would've been epic. Almost no 360's on the market, I do understand why though... but still.
You can use it for CPU only it just has the option to disconnect and add in a GPU block![]()
Yah, understood that... but will look a bit odd with the disconnects on the loops though.
That's why you replace the tubing![]()
That's why you don't buy it when you don't want that kind of an AIO. That's why Corsair's are better in that regard![]()
Well the rad on Corsairs biggest AIO is 280mm long and 27mm thick, This is a 360mm rad, Looks to be about 40mm+ thick so heat dissipation is vastly improved, Has a bigger pump, Probably a D5 variant and a dedicated waterblock for the CPU with 2 quick disconnects so you can cool just the CPU.
Performance wise it will probably make anything Corsair has look like a kids toy ^_^
True that, don't argue on that.
Although, do keep in mind that EK is an watercooling company and as far as I know Corsair isn't.
And if we talk convenience here, Corsair's are easier to maintain![]()
So true
One of the reasons I'm not going to a full watercooling loop, Corsairs offer brilliant performance, Looks neat and tidy, You can monitor temps, Alter fan speed, Pump performance and it literally takes 5 minutes to install![]()
I don't see the point in including the res and QDC's. The amount of systems this will actually fit in compared with a Kelvin or typical pump over block expandable AIO seems like it may be a bit limited by the catastrophically big end tank.
On the other hand the fittings, tubing, fans, blocks and the fact they include a DDC is exceptional. I'm sure this is going to be an expensive one!
JR
Ive had units like this before and the DDC just vibrates and totally ruins the point in watercooling - Id be surprised if this is any different.
