DraftedSpoon
Hello there, I do believe that this keyboard is brilliant and I will enjoy using it for a long time.
The keyboard I am talking about is a Ducky DK9008 Shine or ‘Shining’. My keyboard is using red LED backlighting and Cherry MX Blue key switches, the sound they produce is wonderful.
The Ducky DK9008 Shine is a fully mechanical keyboard with premium features at a relatively low price point. When purchasing this keyboard you are given the choice of key switch and backlight colour you would like. This keyboard feels extremely high quality and has quite a bit of weight to it due to the metal plate build into the keyboard.
The Ducky DK9008 Shine keyboard comes with a couple extra things in the box, a standards USB 2.0 to Mini USB cable (this is because the cable is not attached to the keyboard), a bag containing four extra keycaps (red WASD keycaps), a key puller (keycap removal tool), a USB to PS2 adapter (this is for N-Key rollover) and the user manual.
The backlighting on the Ducky DK9008 Shine is absolutely outstanding and can be changed on-the-fly, using the included lighting profiles: Game Mode (ESC, WASD, Space and up-down-left-right arrows are lit), 60% (All but the number pad is lit), 100% (entire keyboard is lit) and Pulsating Mode (The backlight pulsates between the highest and lowest brightness levels).
The Ducky DK9008 Shine features a few ‘Media shortcut keys’, the keys can be seen below.
On the bottom of the Ducky DK9008 Shine there is a ‘DPI switch’, this switch allows you turn off certain features of the keyboard. (Refer to the user manual guide).
If you have been looking for a mechanical keyboard with great looks, elegant and simple layout and multiple keyboard lighting functions. then this may just be the perfect keyboard for you! As mentioned before, you are given the option of which key switch and backlighting colour is used in the keyboard and it won’t cost you a penny more!
For the money, this keyboard has seriously impressed me and I would recommend it to anyone that asks.
I hope this review has helped you and if in the future you decide to get this keyboard, I would love to hear about your experience.
Thank you.
// Drafted Spoon
(Written with the Ducky DK9008 Shine)
Thank you.
// Drafted Spoon
