Dawelio
Active member
Hey guys,
I've been on the search for a dual 3.5" HDD cage, as my Fractal Design Arc Mini only has a cage which can hold 3 HDDs, but that is too many for me.
As I will ONLY be using 2 3.5" harddrives, I'm looking for a dual bay cage for them, that can be mounted on the bottom of the floor of the case.
Something like this is what I'm after, although these seems to only come in 4 bay versions, seems like finding a dual bay only cage is quite difficult.
http://www.ebay.com/itm/External-In...754?pt=LH_DefaultDomain_0&hash=item3cf70b4d22
Also have found these, but not sure on them though...
To put side by side: http://www.ebay.com/itm/Silverstone...954?pt=LH_DefaultDomain_0&hash=item3a81402d62
From another case:
https://www.ncases.com/product/M1 Accessories
Not sure if this one can work or how to implement it to the bottom of the case?...
http://eshop.macsales.com/item/OWC/MM52T35/
Any help on this is much appreciated... basically, what I'm after, to avoid any confusing, is to find something like an harddrive cage, that can ONLY support up to 2 x 3.5" harddrives, such as two Western Digital Caviar Green and Black harddrives.
Of course I will do some modding/drilling in order to get it to fit and get secured in the case.
Thank you,
Chrazey
From another case:
Thank you,
Chrazey
