Hi, I've just registered here as I stumbled across this thread while looking for an eta on the different colors. Anyway I thought I'd let you know what I know....
I just started a new build and bought their platinum ram in the hopes that in the future they would release a red upgrade. Failing that modding should be simple.
Anyway I emailed Corsair directly a while back asking them if they plan on releasing a red kit... Unfortunately I deleted the email so I cant show you  exactly what they said. But, they replied the next day which in itself I was impressed with. And as I can remember, they said that red is a more difficult color to produce effectively and that they do plan on releasing other colors.
i hope this helps
