do we need ddr4?
umarsbid
Hi well I want to know something do we need ddr4 as the is very high price at the moment. In term benchmark and price does ddr4 is way to dear so for the same price you can get 32gb ddr3 kit with speeds that are the same as ddr4. So I want to ask is it faster and do we need ddr4 yet?
Short answer is no, you do not need ddr4. We on the other hand is a maybe. For the average user, sticking with ddr3 is perfectly fine, you wont notice the difference. Only the wad of cash you have in the wallet when going the DDR3 route.
Point to make clear is unless rendering you dont need 32GB
If you are rendering you need more cores and that means X99 and DDR4
