do i bother reinstalling or not?
WelshD1K
Wel my new mobo has dolby bla bla on it .. and i have a asus xonar d2 . so is it worth reisntaing it? my mobo is a ga z68x ud3p
btw and itas driving a set of z5500's if it makes any difference
Why on earth wouldnt you, defo install it.
Its superior in every why, the onborard must be at 85-88 DB snr while you asus is doing 118 DB snr.
Yup, I'd suggest doing a clean uninstall of your onboard sound drivers, reboot and then install the Asus Xonar D2.
Check out K-lite codec pack as well, has alot of good tools to configure your sound to your speakers, and its free. A good rise in over-all audio quality too
