DirectX 12 Explicit Multi-GPU Performance Review with Ashes of the Singularity
All valid points :)
I'm expecting a 20%+ performance increase, Quite conservative and realistic IMO.
I don't even think it's going to be 20%+ performance increase, I'm guessing more 10% performance increase.
Why would they make a GPU with that more of a performance increase when it's going to hurt there next series cards after Pascal & Polaris.
IMO It's only going to be very minor performance increase that why i said only 10%
If i'm wrong, I'm wrong
They are doubling the number of transistors on the die. They could therefore in theory gain a 100% increase in performance( it won't due to physics) but I suspect a 20-30% real world gain is pretty possible. Finfet is much easier to get high clocks along with the fact it's inherently faster. Additionally architecture improvements would give us more performance and having certain additional decode/encode abilities will allow us to do certain tasks with minimal computational needs. It all adds up.
This is true for both companies. I suspect AMD has more to gain overall due to using 14nm instead of 16nm like Nvidia
I'm still not buying into hype & speculation
That isn't hype. It's what happens when you double the transistor count and give it a better architecture... What is speculating is the amount of performance gain, however, again it falls back to what I just said and 20-30% is pretty obtainable with these changes, especially since high clockspeeds with FinFet are easier to achieve than previous planar designs and have better voltage leak properties(which is fact) which again can be applied to higher overclocks.
Speculations etc really dont matter. Just the jump from 28nm to 14nm will allow for significant gains on the efficiency side. Ive been thinking a more modest 30% gain for the flagship all in all. Unless they decide to be very and I mean very conservative with the TDP on it... Which for a flagship is just..... keep TDP low on the budget/mid ranged.
What I am most excited about is the notebook side. I am still running my trusty albeit outdated 680m SLI setup.
Yeah top end cards will get the most performance gains. Lower end models will probably be between 15-20% with much lower TDPs, so I agree with you there:)
Notebooks probably gain the most though, much much lower TDPs means less heat and performance can rise quite a bit at the same time, and still be lower than previous generations.
i remember something a few years ago but it was some sort of a mod wasn't it nothing official?
Can't see Microsoft taking it well if Nvidia put a spanner in the works
Ya it would probably upset MS to an extent. They are trying to sell the idea they want to support PC gaming and bring it all back, Nvidia not supporting a big feature(in many consumers eyes) wouldn't really help that notion
Picked up another 980 GTX for a steal of a price so when that arrives I'll be giving it a test.
Great news that we hopefully in the future wont have to rely on nvidia or amd creating the correct drivers for their own brand multi GPU setup.
Code:
== Hardware Configuration ================================================
GPU 0:		NVIDIA GeForce GTX 980
CPU:		GenuineIntel
		Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Physical Cores:			4
Logical Cores:			8
Physical Memory: 		16333 MB
Allocatable Memory:		134217727 MB
== Configuration =========================================================
API:						DirectX 12
Quality Preset:					Extreme
Resolution:				1920x1200
Fullscreen:				True
Bloom Quality:				High
PointLight Quality:			High
Glare Quality:				High
Shading Samples: 			16 million
Terrain Shading Samples: 		8 million
Shadow Quality:				High
Temporal AA Duration:			0
Temporal AA Time Slice:			0
Multisample Anti-Aliasing:		4x
Texture Rank :				1
== Total Avg Results =================================================
Total Time:					 60.004467 ms per frame
Avg Framerate:					 49.455208 FPS (20.220318 ms)
Weighted Framerate:				 47.274799 FPS (21.152920 ms)
CPU frame rate (estimated if not GPU bound):	 89.783539 FPS (11.137899 ms)
Percent GPU Bound:				 47.393166 %
Driver throughput (Batches per ms):		 5515.633789 Batches
Average Batches per frame:			 15271.237305 Batches
== Results ===============================================================
BenchMark 0
TestType: Full System Test
== Sub Mark Normal Batch =================================================
Total Time:					 71.043053 ms per frame
Avg Framerate:					 53.770210 FPS (18.597658 ms)
Weighted Framerate:				 50.878983 FPS (19.654480 ms)
CPU frame rate (estimated if not GPU bound):	 92.413887 FPS (10.820885 ms)
Percent GPU Bound:				 55.621784 %
Driver throughput (Batches per ms):		 3951.966309 Batches
Average Batches per frame:			 5879.471680 Batches
== Sub Mark Medium Batch =================================================
Total Time:					 55.961731 ms per frame
Avg Framerate:					 50.480927 FPS (19.809462 ms)
Weighted Framerate:				 47.471851 FPS (21.065115 ms)
CPU frame rate (estimated if not GPU bound):	 100.008118 FPS (9.999188 ms)
Percent GPU Bound:				 67.130577 %
Driver throughput (Batches per ms):		 5095.379883 Batches
Average Batches per frame:			 12214.244141 Batches
== Sub Mark Heavy Batch =================================================
Total Time:					 53.008617 ms per frame
Avg Framerate:					 44.936089 FPS (22.253828 ms)
Weighted Framerate:				 43.977005 FPS (22.739157 ms)
CPU frame rate (estimated if not GPU bound):	 79.405273 FPS (12.593622 ms)
Percent GPU Bound:				 19.427147 %
Driver throughput (Batches per ms):		 6707.456543 Batches
Average Batches per frame:			 27719.996094 Batches
== Shot Mid Artemis Battle Shot =========================================
Total Time:					 5.007545 ms per frame
Avg Framerate:					 39.140934 FPS (25.548700 ms)
Weighted Framerate:				 36.207325 FPS (27.618721 ms)
CPU frame rate (estimated if not GPU bound):	 99.004906 FPS (10.100510 ms)
Percent GPU Bound:				 57.468861 %
Driver throughput (Batches per ms):		 2701.078857 Batches
Average Batches per frame:			 3674.362061 Batches
== Shot Far Artemis Battle Shot =========================================
Total Time:					 4.986735 ms per frame
Avg Framerate:					 41.710659 FPS (23.974688 ms)
Weighted Framerate:				 40.018887 FPS (24.988201 ms)
CPU frame rate (estimated if not GPU bound):	 82.759903 FPS (12.083146 ms)
Percent GPU Bound:				 65.975723 %
Driver throughput (Batches per ms):		 4522.021973 Batches
Average Batches per frame:			 11828.909180 Batches
== Shot Satellite Shot =========================================
Total Time:					 4.998224 ms per frame
Avg Framerate:					 42.415062 FPS (23.576530 ms)
Weighted Framerate:				 41.294910 FPS (24.216059 ms)
CPU frame rate (estimated if not GPU bound):	 66.636688 FPS (15.006748 ms)
Percent GPU Bound:				 30.430773 %
Driver throughput (Batches per ms):		 6116.017090 Batches
Average Batches per frame:			 30221.402344 Batches
== Shot Fighters Satellite Chase =========================================
Total Time:					 11.997862 ms per frame
Avg Framerate:					 59.510601 FPS (16.803728 ms)
Weighted Framerate:				 59.135941 FPS (16.910191 ms)
CPU frame rate (estimated if not GPU bound):	 68.319008 FPS (14.637214 ms)
Percent GPU Bound:				 24.387426 %
Driver throughput (Batches per ms):		 2355.017822 Batches
Average Batches per frame:			 2460.035156 Batches
== Shot Surrounded T3 Shot =========================================
Total Time:					 4.998928 ms per frame
Avg Framerate:					 39.408455 FPS (25.375265 ms)
Weighted Framerate:				 36.355148 FPS (27.506420 ms)
CPU frame rate (estimated if not GPU bound):	 109.278610 FPS (9.150922 ms)
Percent GPU Bound:				 64.211594 %
Driver throughput (Batches per ms):		 3391.973389 Batches
Average Batches per frame:			 4756.324707 Batches
== Shot Overhead Top Battle Shot =========================================
Total Time:					 5.024398 ms per frame
Avg Framerate:					 48.961086 FPS (20.424383 ms)
Weighted Framerate:				 44.609432 FPS (22.416784 ms)
CPU frame rate (estimated if not GPU bound):	 103.963165 FPS (9.618792 ms)
Percent GPU Bound:				 58.235023 %
Driver throughput (Batches per ms):		 4227.264648 Batches
Average Batches per frame:			 8420.784180 Batches
== Shot Sideline Battle Shot =========================================
Total Time:					 4.977458 ms per frame
Avg Framerate:					 51.230972 FPS (19.519444 ms)
Weighted Framerate:				 48.288647 FPS (20.708801 ms)
CPU frame rate (estimated if not GPU bound):	 101.206032 FPS (9.880835 ms)
Percent GPU Bound:				 69.249626 %
Driver throughput (Batches per ms):		 4466.965820 Batches
Average Batches per frame:			 9257.330078 Batches
== Shot Bomber Chase Cam =========================================
Total Time:					 7.008280 ms per frame
Avg Framerate:					 60.214485 FPS (16.607300 ms)
Weighted Framerate:				 57.613331 FPS (17.357094 ms)
CPU frame rate (estimated if not GPU bound):	 98.003876 FPS (10.203678 ms)
Percent GPU Bound:				 60.492496 %
Driver throughput (Batches per ms):		 4115.289551 Batches
Average Batches per frame:			 8729.817383 Batches
== Shot Long Shot =========================================
Total Time:					 9.987196 ms per frame
Avg Framerate:					 41.653332 FPS (24.007683 ms)
Weighted Framerate:				 39.193378 FPS (25.514513 ms)
CPU frame rate (estimated if not GPU bound):	 96.690414 FPS (10.342287 ms)
Percent GPU Bound:				 68.943222 %
Driver throughput (Batches per ms):		 4913.114746 Batches
Average Batches per frame:			 13464.154297 Batches
== Shot Fighters Chase Cam 1 =========================================
Total Time:					 14.998560 ms per frame
Avg Framerate:					 55.271969 FPS (18.092354 ms)
Weighted Framerate:				 52.543991 FPS (19.031672 ms)
CPU frame rate (estimated if not GPU bound):	 102.644089 FPS (9.742402 ms)
Percent GPU Bound:				 73.162987 %
Driver throughput (Batches per ms):		 4982.804688 Batches
Average Batches per frame:			 11961.133789 Batches
== Shot Satellite Shot 2 =========================================
Total Time:					 8.007347 ms per frame
Avg Framerate:					 46.332451 FPS (21.583145 ms)
Weighted Framerate:				 44.512913 FPS (22.465391 ms)
CPU frame rate (estimated if not GPU bound):	 81.631203 FPS (12.250217 ms)
Percent GPU Bound:				 14.301075 %
Driver throughput (Batches per ms):		 6714.332031 Batches
Average Batches per frame:			 26714.562500 Batches
== Shot Top Battle Shot =========================================
Total Time:					 5.002299 ms per frame
Avg Framerate:					 48.377758 FPS (20.670656 ms)
Weighted Framerate:				 46.746510 FPS (21.391972 ms)
CPU frame rate (estimated if not GPU bound):	 91.620132 FPS (10.914632 ms)
Percent GPU Bound:				 62.060577 %
Driver throughput (Batches per ms):		 5395.281250 Batches
Average Batches per frame:			 17381.945313 Batches
== Shot Sideline Battle Shot 2 =========================================
Total Time:					 9.993360 ms per frame
Avg Framerate:					 46.430836 FPS (21.537413 ms)
Weighted Framerate:				 46.077816 FPS (21.702417 ms)
CPU frame rate (estimated if not GPU bound):	 88.771057 FPS (11.264934 ms)
Percent GPU Bound:				 17.048412 %
Driver throughput (Batches per ms):		 6382.635742 Batches
Average Batches per frame:			 22145.068359 Batches
== Shot Fighters Chase Cam 2 =========================================
Total Time:					 10.001415 ms per frame
Avg Framerate:					 48.093193 FPS (20.792963 ms)
Weighted Framerate:				 45.779839 FPS (21.843678 ms)
CPU frame rate (estimated if not GPU bound):	 108.918152 FPS (9.181206 ms)
Percent GPU Bound:				 78.126945 %
Driver throughput (Batches per ms):		 4026.940674 Batches
Average Batches per frame:			 7192.515625 Batches
== Shot Long Shot 3 =========================================
Total Time:					 5.001041 ms per frame
Avg Framerate:					 41.791302 FPS (23.928425 ms)
Weighted Framerate:				 40.625927 FPS (24.614824 ms)
CPU frame rate (estimated if not GPU bound):	 73.753143 FPS (13.558744 ms)
Percent GPU Bound:				 10.865620 %
Driver throughput (Batches per ms):		 7334.468750 Batches
Average Batches per frame:			 32631.865234 Batches
== Shot Mountain Air Battle Shot =========================================
Total Time:					 9.997338 ms per frame
Avg Framerate:					 56.014908 FPS (17.852390 ms)
Weighted Framerate:				 53.507252 FPS (18.689054 ms)
CPU frame rate (estimated if not GPU bound):	 121.899132 FPS (8.203504 ms)
Percent GPU Bound:				 63.431442 %
Driver throughput (Batches per ms):		 6040.187500 Batches
Average Batches per frame:			 8478.922852 Batches
== Shot Sideline Battle Shot 3 =========================================
Total Time:					 5.001871 ms per frame
Avg Framerate:					 58.378155 FPS (17.129696 ms)
Weighted Framerate:				 57.466896 FPS (17.401323 ms)
CPU frame rate (estimated if not GPU bound):	 90.937378 FPS (10.996578 ms)
Percent GPU Bound:				 78.797699 %
Driver throughput (Batches per ms):		 3976.615234 Batches
Average Batches per frame:			 8257.502930 Batches
== Shot Panoramic Battle Shot =========================================
Total Time:					 9.996480 ms per frame
Avg Framerate:					 46.816479 FPS (21.360001 ms)
Weighted Framerate:				 46.127529 FPS (21.679029 ms)
CPU frame rate (estimated if not GPU bound):	 81.247604 FPS (12.308056 ms)
Percent GPU Bound:				 23.729349 %
Driver throughput (Batches per ms):		 6738.465332 Batches
Average Batches per frame:			 27300.214844 Batches
== Shot Mountain Air Battle Shot 2 =========================================
Total Time:					 4.997995 ms per frame
Avg Framerate:					 55.022057 FPS (18.174530 ms)
Weighted Framerate:				 52.188721 FPS (19.161228 ms)
CPU frame rate (estimated if not GPU bound):	 109.993347 FPS (9.091459 ms)
Percent GPU Bound:				 52.140396 %
Driver throughput (Batches per ms):		 8178.276367 Batches
Average Batches per frame:			 13175.963867 Batches
== Shot Low Vista =========================================
Total Time:					 10.008336 ms per frame
Avg Framerate:					 43.563686 FPS (22.954899 ms)
Weighted Framerate:				 42.958809 FPS (23.278114 ms)
CPU frame rate (estimated if not GPU bound):	 79.846504 FPS (12.524030 ms)
Percent GPU Bound:				 20.570808 %
Driver throughput (Batches per ms):		 6610.654785 Batches
Average Batches per frame:			 28106.953125 Batches
== Shot Fighters Satellite Chase 2 =========================================
Total Time:					 6.988808 ms per frame
Avg Framerate:					 59.380657 FPS (16.840500 ms)
Weighted Framerate:				 58.874920 FPS (16.985161 ms)
CPU frame rate (estimated if not GPU bound):	 72.387733 FPS (13.814496 ms)
Percent GPU Bound:				 24.404642 %
Driver throughput (Batches per ms):		 4151.087402 Batches
Average Batches per frame:			 4242.718262 Batches
== Shot High Vista =========================================
Total Time:					 5.003885 ms per frame
Avg Framerate:					 44.365524 FPS (22.540024 ms)
Weighted Framerate:				 43.243164 FPS (23.125044 ms)
CPU frame rate (estimated if not GPU bound):	 74.237213 FPS (13.470333 ms)
Percent GPU Bound:				 19.063728 %
Driver throughput (Batches per ms):		 7357.334473 Batches
Average Batches per frame:			 34164.312500 Batches
== Shot Small Mountain Battle =========================================
Total Time:					 5.016663 ms per frame
Avg Framerate:					 59.202705 FPS (16.891121 ms)
Weighted Framerate:				 57.791180 FPS (17.303679 ms)
CPU frame rate (estimated if not GPU bound):	 119.948769 FPS (8.336892 ms)
Percent GPU Bound:				 70.448746 %
Driver throughput (Batches per ms):		 2730.843994 Batches
Average Batches per frame:			 3066.390381 Batches
== Shot End Scene =========================================
Total Time:					 11.011455 ms per frame
Avg Framerate:					 54.488712 FPS (18.352425 ms)
Weighted Framerate:				 50.905193 FPS (19.644361 ms)
CPU frame rate (estimated if not GPU bound):	 105.365517 FPS (9.490771 ms)
Percent GPU Bound:				 65.942154 %
Driver throughput (Batches per ms):		 4706.361328 Batches
Average Batches per frame:			 10562.532227 Batches
Something that makes a big difference with 2 card setups is the CPU.
There is quite a difference going from a 4 or 6 core to an 8 core 5960X.
For a single card there is practically no difference as long as you use a modern CPU.
Below is a couple of my TXs and 5960X with the settings cranked up at 1080p. A single TX using the same setup scores 53.9fps.
2 x TX @1501/2002
5960X @4.0
1080p
361.91
Oxide Games
Ashes Benchmark Test - ©2015
C:\Users\Keve\Documents\My Games\Ashes of the Singularity\Benchmarks\Output_16_02_28_0739.txt
Version 0.90.17585
02/28/2016 07:42
GPU 0: NVIDIA GeForce GTX TITAN X
GPU 1: NVIDIA GeForce GTX TITAN X
CPU: GenuineIntel
Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
Physical Cores: 8
Logical Cores: 16
Physical Memory: 16253 MB
API: DirectX 12
Quality Preset: Custom
Resolution: 1920x1080
Fullscreen: True
Bloom Quality: High
Glare Quality: High
Terrain Shading Samples: 16 million
Multisample Anti-Aliasing: 8x
Texture Rank : 1
Total Time: 60.001873 ms per frame
Avg Framerate: 97.916809 FPS (10.212751 ms)
Weighted Framerate: 96.338928 FPS (10.380020 ms)
CPU frame rate (estimated if not GPU bound): 104.865555 FPS (9.536019 ms)
Percent GPU Bound: 0.000000 %
Driver throughput (Batches per ms): 3828.350342 Batches
Average Batches per frame: 16817.607422 Batches
BenchMark 0
Total Time: 70.989044 ms per frame
Avg Framerate: 105.466980 FPS (9.481641 ms)
Weighted Framerate: 103.519661 FPS (9.660001 ms)
CPU frame rate (estimated if not GPU bound): 111.275223 FPS (8.986727 ms)
Driver throughput (Batches per ms): 1741.258423 Batches
Average Batches per frame: 6803.792969 Batches
Total Time: 56.030804 ms per frame
Avg Framerate: 98.677864 FPS (10.133986 ms)
Weighted Framerate: 97.386475 FPS (10.268366 ms)
CPU frame rate (estimated if not GPU bound): 105.862549 FPS (9.446211 ms)
Driver throughput (Batches per ms): 3527.537354 Batches
Average Batches per frame: 13752.834961 Batches
Total Time: 52.985764 ms per frame
Avg Framerate: 90.722481 FPS (11.022627 ms)
Weighted Framerate: 89.192604 FPS (11.211693 ms)
CPU frame rate (estimated if not GPU bound): 98.278938 FPS (10.175120 ms)
Driver throughput (Batches per ms): 7223.054688 Batches
Average Batches per frame: 29896.191406 Batches
Got my 2nd 980 GTX now. Can see an increase over the original. Early days still but I think they are on the right road making it non vendor driver reliant.
Code:
GPU 1:		NVIDIA GeForce GTX 980
CPU:		GenuineIntel
Physical Cores:			4
Logical Cores:			8
API:						DirectX 12
Fullscreen:				True
Bloom Quality:				High
Glare Quality:				High
Texture Rank :				1
Total Time:					 60.001602 ms per frame
Avg Framerate:					 63.808521 FPS (15.671888 ms)
Weighted Framerate:				 61.666008 FPS (16.216391 ms)
CPU frame rate (estimated if not GPU bound):	 83.215858 FPS (12.016940 ms)
Percent GPU Bound:				 58.023857 %
Driver throughput (Batches per ms):		 4066.892822 Batches
Average Batches per frame:			 15619.570313 Batches
BenchMark 0
Total Time:					 71.011284 ms per frame
Avg Framerate:					 68.735558 FPS (14.548512 ms)
Weighted Framerate:				 65.134171 FPS (15.352925 ms)
CPU frame rate (estimated if not GPU bound):	 91.098694 FPS (10.977106 ms)
Percent GPU Bound:				 58.961765 %
Driver throughput (Batches per ms):		 1919.881836 Batches
Average Batches per frame:			 6107.689453 Batches
Total Time:					 56.013218 ms per frame
Avg Framerate:					 58.986076 FPS (16.953154 ms)
Weighted Framerate:				 57.595821 FPS (17.362371 ms)
CPU frame rate (estimated if not GPU bound):	 87.866013 FPS (11.380965 ms)
Percent GPU Bound:				 76.932785 %
Driver throughput (Batches per ms):		 3930.756592 Batches
Average Batches per frame:			 12425.005859 Batches
Total Time:					 52.980301 ms per frame
Avg Framerate:					 64.457916 FPS (15.513997 ms)
Weighted Framerate:				 62.759403 FPS (15.933867 ms)
CPU frame rate (estimated if not GPU bound):	 73.031357 FPS (13.692749 ms)
Percent GPU Bound:				 38.177021 %
Driver throughput (Batches per ms):		 6347.984375 Batches
Average Batches per frame:			 28326.015625 Batches
Total Time:					 4.981557 ms per frame
Avg Framerate:					 43.962158 FPS (22.746838 ms)
Weighted Framerate:				 43.692120 FPS (22.887423 ms)
CPU frame rate (estimated if not GPU bound):	 78.596169 FPS (12.723267 ms)
Percent GPU Bound:				 87.689491 %
Driver throughput (Batches per ms):		 1278.128174 Batches
Average Batches per frame:			 4318.730469 Batches
Total Time:					 5.012318 ms per frame
Avg Framerate:					 49.278599 FPS (20.292786 ms)
Weighted Framerate:				 48.971821 FPS (20.419907 ms)
CPU frame rate (estimated if not GPU bound):	 75.092949 FPS (13.316830 ms)
Percent GPU Bound:				 81.116058 %
Driver throughput (Batches per ms):		 3294.882813 Batches
Average Batches per frame:			 11338.635742 Batches
Total Time:					 4.988073 ms per frame
Avg Framerate:					 43.704258 FPS (22.881067 ms)
Weighted Framerate:				 43.423138 FPS (23.029198 ms)
CPU frame rate (estimated if not GPU bound):	 60.704170 FPS (16.473333 ms)
Percent GPU Bound:				 85.043213 %
Driver throughput (Batches per ms):		 5592.668457 Batches
Average Batches per frame:			 30666.255859 Batches
Total Time:					 12.009088 ms per frame
Avg Framerate:					 82.770653 FPS (12.081576 ms)
Weighted Framerate:				 81.432388 FPS (12.280127 ms)
CPU frame rate (estimated if not GPU bound):	 87.474106 FPS (11.431954 ms)
Percent GPU Bound:				 22.505997 %
Driver throughput (Batches per ms):		 828.783997 Batches
Average Batches per frame:			 2651.065186 Batches
Total Time:					 5.002238 ms per frame
Avg Framerate:					 35.584076 FPS (28.102459 ms)
Weighted Framerate:				 35.145634 FPS (28.453037 ms)
CPU frame rate (estimated if not GPU bound):	 88.232765 FPS (11.333658 ms)
Percent GPU Bound:				 98.396507 %
Driver throughput (Batches per ms):		 1630.576172 Batches
Average Batches per frame:			 5104.062012 Batches
Total Time:					 5.009792 ms per frame
Avg Framerate:					 39.722206 FPS (25.174835 ms)
Weighted Framerate:				 39.505791 FPS (25.312744 ms)
CPU frame rate (estimated if not GPU bound):	 84.999229 FPS (11.764812 ms)
Percent GPU Bound:				 95.224205 %
Driver throughput (Batches per ms):		 2998.276367 Batches
Average Batches per frame:			 9482.924805 Batches
Total Time:					 4.985435 ms per frame
Avg Framerate:					 52.352512 FPS (19.101280 ms)
Weighted Framerate:				 51.817619 FPS (19.298454 ms)
CPU frame rate (estimated if not GPU bound):	 89.791542 FPS (11.136907 ms)
Percent GPU Bound:				 85.833694 %
Driver throughput (Batches per ms):		 3151.840332 Batches
Average Batches per frame:			 9773.819336 Batches
Total Time:					 6.999502 ms per frame
Avg Framerate:					 71.290779 FPS (14.027060 ms)
Weighted Framerate:				 69.638977 FPS (14.359775 ms)
CPU frame rate (estimated if not GPU bound):	 89.644699 FPS (11.155149 ms)
Percent GPU Bound:				 57.684017 %
Driver throughput (Batches per ms):		 2831.775391 Batches
Average Batches per frame:			 8873.973633 Batches
Total Time:					 9.992014 ms per frame
Avg Framerate:					 49.239323 FPS (20.308971 ms)
Weighted Framerate:				 48.559368 FPS (20.593349 ms)
CPU frame rate (estimated if not GPU bound):	 84.699219 FPS (11.806484 ms)
Percent GPU Bound:				 86.125908 %
Driver throughput (Batches per ms):		 4197.548340 Batches
Average Batches per frame:			 13270.312500 Batches
Total Time:					 15.009312 ms per frame
Avg Framerate:					 65.359428 FPS (15.300012 ms)
Weighted Framerate:				 64.269791 FPS (15.559409 ms)
CPU frame rate (estimated if not GPU bound):	 92.011017 FPS (10.868263 ms)
Percent GPU Bound:				 75.030029 %
Driver throughput (Batches per ms):		 4111.182129 Batches
Average Batches per frame:			 12597.006836 Batches
Total Time:					 7.992226 ms per frame
Avg Framerate:					 47.671322 FPS (20.976973 ms)
Weighted Framerate:				 47.110489 FPS (21.226694 ms)
CPU frame rate (estimated if not GPU bound):	 73.419533 FPS (13.620355 ms)
Percent GPU Bound:				 93.592438 %
Driver throughput (Batches per ms):		 6355.557129 Batches
Average Batches per frame:			 27273.310547 Batches
Total Time:					 5.000802 ms per frame
Avg Framerate:					 54.591244 FPS (18.317957 ms)
Weighted Framerate:				 53.948376 FPS (18.536240 ms)
CPU frame rate (estimated if not GPU bound):	 82.985062 FPS (12.050362 ms)
Percent GPU Bound:				 81.020119 %
Driver throughput (Batches per ms):		 5228.458496 Batches
Average Batches per frame:			 17571.953125 Batches
Total Time:					 10.004737 ms per frame
Avg Framerate:					 74.764587 FPS (13.375317 ms)
Weighted Framerate:				 73.726891 FPS (13.563573 ms)
CPU frame rate (estimated if not GPU bound):	 83.164833 FPS (12.024313 ms)
Percent GPU Bound:				 39.238625 %
Driver throughput (Batches per ms):		 6058.510742 Batches
Average Batches per frame:			 22396.884766 Batches
Total Time:					 9.997477 ms per frame
Avg Framerate:					 66.916885 FPS (14.943911 ms)
Weighted Framerate:				 66.085236 FPS (15.131973 ms)
CPU frame rate (estimated if not GPU bound):	 91.278214 FPS (10.955517 ms)
Percent GPU Bound:				 71.383736 %
Driver throughput (Batches per ms):		 2417.689941 Batches
Average Batches per frame:			 7685.625000 Batches
Total Time:					 5.002714 ms per frame
Avg Framerate:					 66.164085 FPS (15.113940 ms)
Weighted Framerate:				 65.920982 FPS (15.169678 ms)
CPU frame rate (estimated if not GPU bound):	 66.266998 FPS (15.090467 ms)
Percent GPU Bound:				 3.258358 %
Driver throughput (Batches per ms):		 6659.074219 Batches
Average Batches per frame:			 33515.015625 Batches
Total Time:					 10.003609 ms per frame
Avg Framerate:					 80.370995 FPS (12.442299 ms)
Weighted Framerate:				 79.257515 FPS (12.617100 ms)
CPU frame rate (estimated if not GPU bound):	 94.823196 FPS (10.545943 ms)
Percent GPU Bound:				 47.934418 %
Driver throughput (Batches per ms):		 2723.182617 Batches
Average Batches per frame:			 8669.060547 Batches
Total Time:					 5.000598 ms per frame
Avg Framerate:					 63.392422 FPS (15.774756 ms)
Weighted Framerate:				 62.440102 FPS (16.015348 ms)
CPU frame rate (estimated if not GPU bound):	 95.699348 FPS (10.449391 ms)
Percent GPU Bound:				 80.087265 %
Driver throughput (Batches per ms):		 2845.035400 Batches
Average Batches per frame:			 8684.211914 Batches
Total Time:					 9.994944 ms per frame
Avg Framerate:					 68.134453 FPS (14.676863 ms)
Weighted Framerate:				 67.260742 FPS (14.867514 ms)
CPU frame rate (estimated if not GPU bound):	 75.207954 FPS (13.296466 ms)
Percent GPU Bound:				 37.539085 %
Driver throughput (Batches per ms):		 6415.977539 Batches
Average Batches per frame:			 27883.837891 Batches
Total Time:					 5.002614 ms per frame
Avg Framerate:					 83.356407 FPS (11.996678 ms)
Weighted Framerate:				 82.579941 FPS (12.109478 ms)
CPU frame rate (estimated if not GPU bound):	 90.436432 FPS (11.057490 ms)
Percent GPU Bound:				 32.981636 %
Driver throughput (Batches per ms):		 4336.021973 Batches
Average Batches per frame:			 13569.047852 Batches
Total Time:					 9.997564 ms per frame
Avg Framerate:					 73.017784 FPS (13.695294 ms)
Weighted Framerate:				 72.755440 FPS (13.744678 ms)
CPU frame rate (estimated if not GPU bound):	 73.144264 FPS (13.671612 ms)
Percent GPU Bound:				 2.772021 %
Driver throughput (Batches per ms):		 6335.999023 Batches
Average Batches per frame:			 29280.720703 Batches
Total Time:					 6.998300 ms per frame
Avg Framerate:					 92.736809 FPS (10.783205 ms)
Weighted Framerate:				 91.946999 FPS (10.875831 ms)
CPU frame rate (estimated if not GPU bound):	 95.807350 FPS (10.437613 ms)
Percent GPU Bound:				 18.319780 %
Driver throughput (Batches per ms):		 1483.796143 Batches
Average Batches per frame:			 4749.222168 Batches
Total Time:					 5.000074 ms per frame
Avg Framerate:					 65.199036 FPS (15.337649 ms)
Weighted Framerate:				 64.846718 FPS (15.420981 ms)
CPU frame rate (estimated if not GPU bound):	 65.781128 FPS (15.201928 ms)
Percent GPU Bound:				 7.725342 %
Driver throughput (Batches per ms):		 6963.699219 Batches
Average Batches per frame:			 35113.332031 Batches
Total Time:					 5.009188 ms per frame
Avg Framerate:					 70.470497 FPS (14.190335 ms)
Weighted Framerate:				 69.950882 FPS (14.295745 ms)
CPU frame rate (estimated if not GPU bound):	 97.790810 FPS (10.225910 ms)
Percent GPU Bound:				 76.851738 %
Driver throughput (Batches per ms):		 940.691589 Batches
Average Batches per frame:			 3003.172852 Batches
Total Time:					 11.010635 ms per frame
Avg Framerate:					 57.489868 FPS (17.394369 ms)
Weighted Framerate:				 57.018101 FPS (17.538290 ms)
CPU frame rate (estimated if not GPU bound):	 89.972641 FPS (11.114491 ms)
Percent GPU Bound:				 83.362381 %
Driver throughput (Batches per ms):		 3178.059082 Batches
Average Batches per frame:			 10044.953125 Batches
That's a pretty big score kaap. Nearly double. However the driver overhead seems quite high. Idk if that's because Nvidia don't have much in the way of an official driver for it but still. Never seen a screen shot of 0% not GPU bound which is crazy:D
