The only thing is, is the XXX version, the version i have has overclocked stream processes which cannot be done at home.. Otherwise you can get them to the same if not more speed..
Thank you so much for taking all the time to help me and for all the care you've shown- I'm really grateful - Thanks again for understanding !
I just have one big rpoblem and I thought I'd consult you again. In one of the forums, I've been told that as my Power Supply does'nt meet the minimum mentioned on my Box, I should not overclock.
Actually the Minimum Power Requirement mentioned on my Card's Box is as below -
MINIMUM 400W or greater system power supply (with 12V current rating of 26A)
but what I have now is 500W PSU with 19A on my 12V.
Is this dangerous to the card ? How can I monitor if my card is in danger ? Kindly help me... Should I postpone Overclocking untill I have the correct power supply then ?
500w is cutting it close to the limit if you have a lot of other components in your system, if you have a couple of hard drives and dvd drives then you are going to run out of power
