DFI Crossfire Mobo - A new ERA in XTREME
maverik-sg1
Thanks to anandtech for this info:
So, what will persuade buyers to go to an ATI chipset instead of the current NVIDIA nForce4? First, stock performance has to be at least as good as nForce4. Second, enthusiast features and performance must at least be as good as NVIDIA, but preferably even better. The AMD market is driven by computer enthusiasts and hobbyists, so if you satisfy them, the market will follow. Third, if performance and features are very close to NVIDIA, then value - bang for the buck - becomes a very important factor.
To DFI's credit, many of the features of their new RDX200 board seem to be geared toward an understanding of what it will take to succeed with their new ATI chipset motherboard. Crossfire dual-video is on the board, but the emphasis is on performance and features. DFI lavished all the adjustments and tweak options of their nForce4 board on the RDX200 and then went even further. Oscar Wu found out how to make 4DS DIMMs run at 1T Command Rate and launched that solution with this board. He also claims that he has a working CAS 1.5 on the ATI motherboard, and the options for CAS 1.0 and 1.5 are available in the BIOS. Memory voltage extends to 4.0V, so any memory is supported, but this is done without special jumpers or a heat-producing work-around.
DFI firmly believes that these new options, combined with a chipset designed for the enthusiast, will be enough to persuade many buyers to move to the RDX200. So the board is not a value board. This 6-layer design will set the buyer back over $200. Is DFI on target - does the LANParty UT RDX200 have what it takes to win in the market? We will try to answer that question in our closer look at performance, features, and overclocking abilities of the DFI LANParty UT RDX200.
Quick overview
Pros:
4v Dimms with no jumper swapping or additonal heat (a welcome solution)
4x DS Dimms @ 1T (deep joy in that area!!)
Auto switch for Corssfire or single cards (no jumpers or paddles)
Max vcore 2.11v
Typical DFI BIOS options (leads the field in that arena)
Cons:
Max 300ish typical FSB (due to engineering in 4x DS DIMMS runnign 1T)
Only has SATA 1 controllers on board - not SATA 2) no NCQ Support
Poor USB transfer rates (like we care???)
For those who are thinking that surely there's a catch, the answer is "yes, there is". 1T operation is only possible to a frequency of about DDR406, which basically limits it to stock speeds. Above that speed, you must run 4 DS DIMMs at 2T as you normally must. However, at or near stock speeds, the 1T option is a brilliant development that delivers better performance - still great new for FX owners with unlocked multipliers, bring on FX X2's.
Finally we get to see some of these boards, though Grayskull on XS hinted that there is something even better for the overclocker coming from ATI, but no idea what it is lol.
I wish they had done what the ATI reference design did and put all the power components in one area so you can put a larger heatsink on them (and could easily watercool them if necessary)
Awesome board all the same though, ATI have done a lot of work with these boards coming out and i think they do them justice.
Hopefully the Grouper ones (single card) will actually be released soon then i can stop hating my computer so much.
G
PHILIP1193 said:
when is it out and can it run nvidia cards in single form ok?
Phil
Out now in certain stores (if they still have stock) and yes they will run any PCI-E card in single mode.
Cheers
Mav
Nice, i want a crossfire board for xmas. Nice to see their coming :)
Pros:
4v Dimms with no jumper swapping or additonal heat (a welcome solution) - very nice :) not that i would use it cause im gettin TCCD :D
4x DS Dimms @ 1T (deep joy in that area!!) - Cool, the more the merrier.
Auto switch for Corssfire or single cards (no jumpers or paddles) - nice to know!
Max vcore 2.11v - hmmmm...not like my winnie would need it :) but nice to have anyway.
Typical DFI BIOS options (leads the field in that arena) - never used one but they are rated extremely high.
Cons:
Max 300ish typical FSB (due to engineering in 4x DS DIMMS runnign 1T) - :O my winnie doesnt reach that anyway and the 3800+ i wish to upgrade to probably wont either.
Only has SATA 1 controllers on board - not SATA 2) no NCQ Support - i still use IDE
Poor USB transfer rates (like we care???) - hmmm guess i just gotta wait that bit longer for the pr0n to transfer from hard drive to pen drive :P
A lot of people in the US are saying that the high price of it is a thing against the board, but with the ridiculous prices we pay for hardware in the UK anyway it's not so much of an issue here anyway.
G
very true - I am interested in getting the Dlink DGL-4300 to avoid having to use software firewalls whilst gaming - in the US I've found it for $110 - so even with tax and shipping thats still less than the £110 i can get it for in the uk. absolutely pathetic - and i would get it from the US...but i don't want to mess with adapters.
I bought my last graphics card from the US, that was when it was almost £1=$2, i literally saved myself about £100 it was just silly.
G
no sata2? thats silly, what about those of us that bought sata2 for the improved performance?? if I ever get a crossfire board itl be when the dfi BT board comes out in feb next year (with support for ALL tech)... or the dfi nf4 expert board from the usa, which has all the same benefits but has sata2.....
G
yep - i did that for my 6800GT off ebay - saved £100 too. awesome. And its not nice becuase it makes me feel poor when everything costs so much!!!!
