Kaapstad
Active member
I've put forward more facts than you have. Far more.
Nice swerve in the ending sentence though. Yes, trying to get out of it by saying that nobody has the equipment to detect it is a good dodge.
The fact is that you can not dispute what I am saying. Not with any facts. And copying and pasting some one else's opinion does not get you off the hook either.
I'm telling you that I have had 30 years of electronics experience. At least that. I built my ZX80 with my uncle when I was 7, and was taking apart electronic items long before that. My shed was full of them.
So I think I know a wee bit more about solder, its properties and how it reacts than you do. AMD obviously do too. And Intel, when it suits them.
You've put forward your "facts" and I have disputed them. I asked you a simple question. Not even more than one line. you can not answer it because you do not know the answer, do you?
Therefore there is no argument. I politely repeated my question three times, each time you chose to ignore it and then after you had some time to mull it over you say "Nobody has the equipment to check".
Let me reiterate for you, just in case you do not understand electronics (which I am slowly beginning to think you know naff all) soldering a CPU does not create an electrical connection. It's simply flux and tin. If it cracks on the die and cracks enough to cause a problem (like if the flux has perished, as it does and this is why dry joints occur) then you would see an instant rocket in temps. Instant. Once that connection is gone your CPU would simply overheat.
And I have seen no cases of that ever with a soldered CPU. I have been on the internet since 1997 and I have been buying and reading computer mags since I was about 8, and not once have I ever seen a feature about solder on a CPU failing, or for that matter even being a problem. Ever. Not once.
How can you even so much as ponder starting a debate over something using some one else as cover? if you don't know what you are talking about you're better off staying out of it, no?
Go and ask him (seeing as you are using him as your go to) why AMD can solder Ryzen. Not that I trust him of course, given he looks about half my age. And when he gives you an answer bring it here. Let's see if he can explain it, because you obviously can't.
Apart from the fact that you are very rude you have also demonstrated that you don't know as much about the subject as you think you do (try re reading your post).
I would also like to point out that the engineers who work for intel are not idiots and do have a reputation to uphold so they are not going to offer falsehoods that can be challenged by their peers, if they say there is a problem with solder they genuinely believe it.
I am not going to post anymore in this thread as it is totally pointless except to state that people far more qualified than you or me have said there is a problem with solder or putting it another way you are wrong.
