On my motherboard the area to control fans is called H/W monitor I'm not sure about others, If you know what motherboard it is that you have then you can check the manual and it will probably have a section showing you how to do it. If you don't have your manual but know the motherboard you can go to the manufacture website and download a PDF of the manual and it will most likely show/tell you where or how to control fan speeds.
