This build will be almost solely for video rendering and editing, with some gaming on the side. (Adobe Master collection, Sony Vegas)
I've been trying to plan this for over a week now but my opinion keeps swaying so it's time to ask for an outside opinion.
Proposed AMD build (Waiting for Bulldozer)
Total build cost: €1,320.12 (inc delivery Free!)
Asus Crosshair V Formula AM3+ AMD 990FX SB950 DDR3 ATX RoG Series €194.67
Sapphire Technology ATI Radeon 6990 HD 4GB PCI-Express 2.1 x16 DVI 4 x MDP €624.03
OCZ Technology 120GB Vertex 3 Series SATA III 2.5" Solid State Drive €230.44
2 x Corsair Memory 8GB (2 x 4GB) Vengeance DDR3 1866MHz DIMM 240-pin CL9 Red €194.66
Noctua Dual Radiator and Fan CPU Cooler Multi-Socket €76.32
Proposed Intel build:
Total build cost: €1,823.22 (inc delivery Free!)
Intel Core i7-2600K 3.40GHz LGA1155 8MB €279.53
Asus MAXIMUS IV EXTREME REV 3.0 LGA1155 Intel P67 DDR3 Extended ATX €304.82
Corsair Memory 12GB (3 x 4GB) Dominator GT 2000MHz DDR3 DIMM 240-pin CL9 with Airflow Fan €240.45
Corsair 120GB Force GT SATA 6Gb/s 2.5" Solid State Drive (Read 555MB/s, Write 515MB/s) €228.82
Asus GeForce GTX 590 612MHz 3GB GDDR5 PCI-Express 2.0 DVI miniDP €693.28
I've already got a case and 500gb HDD I will reuse. I have a non modular 750w alienware psu which I will probably have to replace, and if I do I will replace it with a Corsair 850 Watt Pro Series Gold AX850 €161.09
I will not be purchasing through dabs.ie I've just used it because it displays the products nicely and has a relatively accurate price.
The two different ram choices are also something I need to decide, 16gb or 12gb of faster ram? I can't really see myself using 16gbs of ram
There isn't a strict budget on this. But I would like to keep it as low as possible while still having very good performance. Just as a guide my budget is 2,000 euro. (1,746 British pounds, 2,867 U.S. dollars)
If there is any more information needed please tell me, and thank you in advance for helping :>.
~~ also: Are there any releases except for BD just around the corner that I should wait for? I'm not in too much of a rush to get this so a couple month wait wouldn't hurt, but, I can't keep waiting because new hardware will always be coming out.
~~~~~ Updated Choice:
TOTAL €2,127.41 (including delivery)`
Total build cost: €1,885.89 + €30 shipping
XFX RADEON HD 6990 830M 4GB DDR5 FOUR MINIDP DVI €571.05
ASUS Maximus IV Extreme-Z Rev 3.0, Sockel 1155, ATX, DDR3 €293.90
Intel Core i7-2600K Box, LGA1155 €255.77
Corsair Force Series GT 120GB SSD 6,4cm (2,5") SATA III €212.09
ASUS DRW-22B3L PATA Bulk schwarz €26.24
Corsair Professional Series Gold AX850, 850 Watt €153.46
WD Caviar Black 1TB SATA 3 8,9cm(3,5") €66.94
Noctua NH-D14, Sockel AM2/AM2+/AM3/775/1366/1156 €67.99
Corsair Obsidian Serie 800D, ATX, ohne Netzteil €238.45
// Have to order the ram twice as Aria give a discount on only one at a time. Works out cheaper including double postage.
// €211.52
Total build cost: €105.76 (including shipping)
8GB Mushkin Redline Ridgeback #996982 (2x4GB) DDR3 1600MHz 7-9-8-24 £ 70.56
// €211.52
