MarcusarilliuS_IRL
Hi guys, as the topic states I have decided to replace my reserator XT with a beefier cooling solution.
It has to be external due to my room layout and where the pc is, and I also want it as quiet as possible.
I need to cool a Q9550@3.82ghz, NB and a Evga GTX280 hc16 and need enough left to cool another GPU when I can afford to stick on in. Was thinking Evga GTX580 classified hydrocopper 3072mb or a 6 or 7 series similar card when they become available/
I am new to this really as the zalman unit was my first and only venture into watercooling so far and have never built a loop from scratch.
Apart from the need for lower temps, the fact that the Zalman has aluminum rads is bothering me(corrosion and less effective than copper for cooling).
I live in Ireland so wanna spec out the parts from the UK if possible so as I don't get robbed with shipping costs.
Was looking at this as a starting point..
http://www.watercoolinguk.co.uk/p/P...nt-18-Fans--Radiator-Grill-&-Cover_20226.html
Should this cool everything I mentioned? Or would a similar cheaper version even do the job I want?
Also saw someone recommend this pump..
http://specialtech.co.uk/spshop/customer/product.php?productid=2381&cat=1191&page=1
So if someone wouldn't mind helping me spec out a loop and tell me what I need to get I'd be very grateful.
My budget is in and around 400 Euros.
Thanks,
Mark.
Thanks,
Mark.
