Compliments of Ins:
BLUE - Covers B. Can play a number of angles but is always in a position to get out if rushed. Notice the window and door positions as these have good cover if rushed. If the team are slightly weaker, then try the lefthand wall on the platform. Good for hs but if they get rushed, throw a fb then jump to the left using the boxes for cover.
GREEN - Watches mid through Double Doors, Long through CT spawn and on eco rounds (rounds we dont buy so that we can save money), they can play close to the DD. Basically this is a very important position and requires a good awper. They have to be able to call when the T's are rushing short so that the people in A can backup. Also if they rush long, this person has to awp through CT spawn. On ecos, the position close to DD is good as you can get hs on people walking short, plus fb them! Also, this close position is good for listening for footsteps in tunnels going to B.
PURPLE - This person has to play smart. If the enemy are agressive then adopt a position out of the site using the wall for cover. This person has cover from Grey player if the rush A via steps. Also Purple can push closer near steps if the T's are that good and occasionally get a boost on the box (position 3) so that they can look down into the lower B tunnels.
GREY - This person plays a floating roll. They assist in covering the A site with Purple but also rush long with Brown at the start of the round. They will flash over the wall at long (near the T doors) to stop any potential rush, then float between the two positions. If they rush A site, this player can watch for the heads of the T's and shoot. They should also fb into the site if this happens to help out Purple.
BROWN - This player will go near the pit, up on the side at the back and also sometimes close to the T doors. This person has to be good close range and should drop into pit throwing fb's if rushed. The idea being that the T's get flashed and Grey backs up to cover and kill. Then Brown can pop up and take them down also. In addition if Purple gets killed, Brown can snipe from pit if needs be while Grey flashes site.
Basically the idea behind these as you'll see is that every player has someone else close to them. They have multiple angels and positions to rotate so that they're not predictable. Also most importantly, they are not isolated. If anyone were to rush, there is the chance to get out and get backup.
