Custom built MM Horizon.
clone38
Here is my MM case i had it built to my spec with fittings for 2 120.3 thermochill rads at the front.
Just come back from the painters with a nice few coats of pearl black with clearcoat.
Also had some airbrush artwork on the side panels.
:yumyum:
Very nice looking mate :)
Is it just me or does that side artwork look like it was designed in Powerpoint :p
im not a fan of cube cases. but this looks nice. i like the pearl paint too...looks nice. When you assembling??
I like some mountain mods cases :)
The best ones I've seen have been watercooled.
All of those 120mm fans are going to be noisy at full speed tho :eek:
If I were to buy one I think I'd probably set it up with 2 or 3 systems inside the 1 case, just to get good use of the space. Also could integrate a 20port switch or similar and have it as a server, router, firewall, client & general network hub all in one :)
Like Azza said mate,had some really silly offers on it,made me laugh :)
I will put up some more piccys if i keep her .
Update
Installed my temp air setup in for now until the X48 boards come out then my watercooling can go in.
Should i spray the mesh black on the filters?
Dam fingerprints need to get some gloves :D
