CTZ's Zombie Pwnage rig
A bit adventurous with the title :o :D
Case: NZXT Lexa (Aluminium)
Case cooling: 2x 120mm in & 1x 120mm + 80mm out
PSU: Hiper Type-r 580w
Motherboard: ABIT AV8-3rd Eye
CPU: AMD 3700+ San Diego @ stock speed
Heatsink compound: OCZ Ultra5+
Heatsink & Fan: Thermaltake Big Typhoon -Air (bolted on!) :D
Memory: 2GB Corsair XMS Pro 3200 @ 3500 (4x 512) 2-3-3-8 :(
Graphics: MSI FX5900Ultra 256MB AGP @ stock speed
Hard Drives: Basic Maxtor/WD 7200rpm IDE drives
Sound: Creative Audigy
CPU Idle temp:
38c (room temp 28c)
CPU load temp: 45-47 (room temp 28c)
Future upgrades - Just so I can enjoy CSS at it's best:worship:
New motherboard (939 Asus/Abit?)
1900XTX or 7900GTX
Front Shot
download.php
Side shot
download.php
download.php
With cover
download.php
Well I don't think i've even seen custom PC mag being sold here but I do read CPU (computer power user), maximum PC, and pc gamer
I'll hafta look around to see if I can find the one you're talking about.
Just a quick update guys! (few pics below too)
Key:
Black = Spec since first post
Green = recently upgraded
Orange = upgraded more than 6 months ago
PSU: Coolermaster iGreen 600w
Motherboard: ASUS P5K-E WiFi
CPU: Intel QX6850 Quad @ stock
Heatsink & Fan (CPU): Thermalright Ultra-120 Extreme + 120mm fan
Memory: GeIL 2GB (2x1GB) PC2-6400C4 800MHz Low Latency DDR2
Graphics: Sapphire 2900XT 512MB @ stock
Heatsink & Fan (GPU): Thermalright HR-03/R600 + 120mm fan (Idles at 44c, compared to 63c stock!!)
Hard Drives: WD Raptor 150
Unfortunately I have to put up with Onboard audio as theres no space for additional cards :(. Is the new heatsink on the ATI worth the sacrifice? Hell yes! It's far more cooler and quitier(sp?) too :D
Oh I never took a pic of the cpu heatsink with a fan, It basically has the 120mm fan from my Big-Typhoon
thanks for your comments guys! I'm really happy with my system, i mainly upgraded to decrease my 3d render times and it has! sweet :D
name='Hatman' said:
You could always mount the cooler the other way around?? Around the card no?
Still looks sweet though :D
:( I tried it but the fan hits the mobo north-bridge but also there would be two 120mm fans opposite each other (1cm ish gap) fighting for the same air :coffee: not sure if that'll be the case in a real world example...
also i thought of leaving the fan off the cpu cooler, flipping the ati cooler as you said and have it draw air fro the heat-sink pushing air towards the cpu heat-sink... it would be hot air though, not completely sure how that would impact the cpus cooling.
PSU with extractor <--cpu heat-sink <---Fan<--gpu heat-sink
or maybe
PSU with extractor <--cpu heat-sink<--Fan <---Fan<--gpu heat-sink
Yeah those temps looks fine and I'm guessing thats quite an improvement on the graphics cards old temps. Just googled that hardware monitor in your screeny, never seen it before, will credit it as your find :)
Whoa?! WTF?! You went back in CPU power?! Why? Temperature worries? :o
That Thermalright 120 NEEDS a fan to be effective otherwise its just pants and even when a fan is attached it needs the right fan. In a review of over 40 different coolers it won by 1C over the AC Freezer Pro but only because they had matched the fan for maximum benefit (fast enough to be good but not loud and provide best temperature - it was a Zalman something). The HSF also needs to face the back of the case (and the rear extraction fan) otherwise the heat from it just fills the case.
Please tell me you just put it to one side until you can sort it :eek:
