Master&Puppet
Hi guys & girls,
I've been playing with OC software for some time but in the last two weeks I have been making inroads into playing with the bios and as of 4 days ago I'm no longer limited by temps thanks to a new case and watercooling. I have a new limitation, however, which is my rather rudimentary knowledge of how this all works. The processes and tools that I've used this far have been largely learnt from this site, so thanks to all of you for that! However I'm sure there's more to be learnt.
I should say before I ramble on that I'm not aiming for the highest MHz score as such but the best performance of the PC on the whole - that may or may not affect any advice given but in my experience so far the highest CPU freq hasn't always yielded the best benchmark...
My rig in my sig but I'm using mobo BIOS v1102 (I've been unsuccessful flashing it but that's another topic) with Prime, HW monitor, AMD Overdrive, AMD fusion.
My current process has been to set the CPU voltage to the OEM's safe upper limit (1.475V) and try different combinations of CPU bus and multiplier, test with Prime and measure performance using Overdrive's benchmarking (taking an average over multiple tests using fusions offline high performance profile). This has netted me a current OC of 3978MHz (17 x 234) @ 1.475 apparently stable having run Prime in blend for 6 hours (temps all below 50C). Before I resign myself to that as maximum, attempt to reduce voltage and run a 24hr test I have some questions if you wouldn't mind:
A. Setting RAM. I've read that faster DRAM freq doesn't necessarily mean better performance so should I have set the tuner to DOCP and the freq to it's lowest (or another value) before OCing the CPU? I've also read in different forums and guides that RAM should be set beforehand; others don't mention it at all and just crack on.
B. The use of auto settings in BIOS in general. There are some that are given and need to be on manual but there are loads of options in the extreme tweaker, particularly voltage related, and I suppose I'm asking - does auto do a bad job of them and if so which ones are the options to be in control of? I'm guessing that there's a point of diminishing returns (MHz added per hour of effort) somewhere here.
I'm particularly interested in RAM & DRAM freq (as already mentioned), NB controls, HT link and PCIE freq (that one is probably in the wrong forum though). Otherwise I have LLCs enabled, spread spectrums & turbo core disabled and have already been playing with CPU bus, multiplier and CPU V as mentioned.
C. Lastly (phew) is there any accepted method, or order in which to adjust things in?
Thanks in advance for any help you guys can offer, I don't expect any individual to answer all the questions in one sitting; it makes sense in my head to put it all in one place...
M&P
M&P
