I forgot if I had posted this comp here or not (problems when you get old
I made this for a Lan Party. As usual I started a week before the Lan and had to rush it but it turned out quite a bit better than the earlier versions.
The Red Crossflow comp had a dual 80mm rad and for this one I really wanted a more performance rad. I found a HP oil cooler for a race car that basically I built a case around.
Here is a shot showing the inside of it.
Here is a shot of the CarbonFiber mobo tray, the water fittings and the pair of laptop hdds.
here is a pict of the underside of the mobo tray showing the PS mount, HDD heatsink and DVD
here is my favorite shot of the wiring (before)
here is the after (first version)
I re designed the inside after swapping the mobo (DFI 590 to Asus P5N E SLI)
notice the HDD heatsink is bigger and mobo wiring is plug in to air box. Also there are the 3 80mm Silverstone 70CFM fans.
I liked the Asus mobo as it was about 1/2" narrower that a standard mobo
Here is a shot of the lower half painted black with the GPUs installed
(notice the DDC pump using a Petras top mounted to the rad)
Here is a shot showing the 1/2" hoses
