Crossfire msi r9 280x gaming cards
ViesisO
i dont burn any stuff with 2 r9 280x cards?
Pc specs:
MB:Asrock Z77 pro 3
PSU:Thermaltake Smart SE 730W 80+bronze modular
CPU:I7 3770K + air cooler
Memory: Crucial Ballistix Sport 8GB dd3 1866mhz cl10 X 2 (16 GB)
SSD+hdd,optical drive,3 case fans and some accessories
gpu cards run stock speed,only cpu multiplier up to 4ghz(not increase voltage).
And i buy 2nd gpu used (i think bit coin miner previous user was,4 month he use this card),because stress load (90%fan speed) 80-90 C temp :( Change thermal paste drop to 60 C temp.and some issue was-M/B bios IGPU Multi-Moniter enabled switched to disabled,then only pass bios and launch win7 64 bit sp1.
Heaven Benchmark 4.0 all at max x8aa (1080p) 1 card 800+,2 cards 1600+ score
Any advice will the system runs ok on long terms (i trow away optical drive- some power...)Or for safe running need search 800+ psu ?
Pc specs:
MB:Asrock Z77 pro 3
How long is a piece of string?
No one knows how long electronics will last dude, it could go on forever perfect or you could have parts die every other week.
2 days ago i buy 2nd card,yesterday i fix it to normal temp.with 1 card all this 2014 goes ideal .and sorry for my bad English ,me from Europa-Baltic states :)
I just worry psu capability ...
Got to here enter your rig details and it'll tell you roughly how many Watts you're using.
minimum pass but recommended no :(
Cant put any cd-rom,sound card,game pad,flash drive,water cooler,card reader :)
Maybe i search some 850+ psu -with some reserve :)
DON'T buy a cheap PSU you WILL regret it buy a Corsair or Seasonic or the like
no *all* corsair psu's are created equal either, be sure to post here to let us know what you're thinking about first and we can help with your decision.
Some corsair PSUs are junk.
You want to go for a 850w gold power supply. EVGA do a good cheap one.
you mean this?
EVGA SuperNOVA 850w G2 Gold
about 14 days to order this ~129 euro :) no one here sells in Latvia
Other possibilities in shops here :
Tacens VALEO V 900W 80+ Silver ~ 88 euro (that i pass)
CHIEFTEC GPM-850C PSU 80+ GOLD ~102 euro
CORSAIR RM850 850W 80+ Gold ~ 143 euro
Seasonic X-850, 850W, 80+ Gold ~210 euro
you mean this?
the "CORSAIR RM850 850W 80+ Gold ~ 143 euro" is more then decent mate.
I concur but i was also looking at that substantial price difference. To me doesn't seem like you're really getting to much more for your dollar.
Seasonic is A LOT more for your dollar over an RM corsair unit dude.
I just ordered EVGA SuperNOVA 850 G2 Gold - 128,99 euro - 10 years Warranty !!!
it,s be my first experience with this company,because here where i,m live it,s very hard get some distributors who sell EVGA,after some 2 weeks i will get it -i hope :)
But thanks anyway for all advises,from amd forum cant get any info,but here i get some use full info :)
The SuperNOVA psus are really very good. Good choice :).
Superflower or Seasonic are the best for power supplies however you can usually get them for cheaper as a named brand (such as XFX or the higher end coolermaster for Seasonic or EVGA for Superflower).
