CRAZY Watercooled Silverstone Precision PS07B Build log
PaddieMayne
OK folks going to be building this for my son, using available spare parts in my garage and some new parts, it will be a water cooled PC using 3 x 120mm rads i have already and the PS07 case that i already have. Im going to mod the case to include at least one side window and maybe more?
Full list of parts below.
Parts i own..
Silverstone Precision PS07B Case
1000
1000
EK-CoolStream RAD XT (120) radiator, x 3
2500k CPU
ASROCK Z-77 Extreme 4-M Mobo
Corsair Memory Vengeance Black 16GB DDR3 1600 MHz CAS 9 XMP
OCZ Agility 3 2.5" SATA III 240GB SSD
650W Corsair Pro Series Gold HX650 Modular PSU, 80 PLUS Gold
Parts to buy...
MSI GeForce GTX 670 Overclocked NVIDIA Graphics Card - 2GB
XSPC X2O 750 Dual Bayres/Pump (Black) V4
XSPC RayStorm CPU WaterBlock (Intel)
XSPC Razor GTX670 VGA Waterblock
XSPC Razor GTX670 Backplate
Pictures and updates to follow soon.​
I have the case stripped down, have installed the 3 x 120mm Rads, and marked the front door up, you can see what i will be cutting out and then inserting a dark grey tinted piece of acrylic for a window. Hoping this will give a good effect when looking at the new 120mm TB VEGAS fans
1000
1000
1000
1000
1000
Front door mod done, it gave me know end of problems with the plastic melting instead of cutting with my jigsaw, so didnt get the finish i wanted so ive used edging strip to tidy it up, but im not happy with that so im looking for better quality edging strip.
However i reckon those blue LEDS will look a treat on the vegas fans behind that smoked acrrylic.
Heres the fans.
1000
1000
And heres how the Front door window mod looks
1000
Heres the updated door now its been redon and im also going to redo the silverstone badge under the window to centralize it..
1000
Oh yeah i just recieved some more WC goodies, i just love the aesthetics of XSPC components, mmmmmmm.
1000
WHAT IT LOOKS LIKE WITH THE PUMP RES COMBO INSTALLED
1000
OK some more pictures coming now, ive had some more bits as i managed to get a GTX670 and a Corsair AX760 PSU off Amazon for a bargain price, saved about £100 in total compared to other retailers :)
So today concentrates mainly on testing and getting the GTX670 Water block and back plate installed.
First up pre-testing the GTX670 using linux mint...
1000
1000
Now some pics with the card stripped and then with the Waterblock and backplate installed...
1000
1000
1000
1000
OK thats all for now folks more very very soon..
Yes it is by exactly 1mm to the left, well spotted Tom, it seems more pronounced in the photograph than in reality for some reason, but i had to do that to avoid further problems, im hoping when its all up and running and the vegas fans are lit up that it will be even less recognizable. The main thing is that my son will be happy, this will be his first ever PC.
Yeah your probably right, but its that build bug Tom, must buy new shiny bits must i must, somebody help me stop please !!
Well, you have one lucky son, my man! :)
And no need to stop building, as long as the money is not a problem!
I'd be concerned about running 2 blocks and 3 rads off that pump tbh...
It's only really meant for a single block, and with multiple blocks, they tend to burn out within a couple of months.
You need a D5 really.
Good work so far though :)
Yeah i was thinking about that too, so ill put it too the test, if it fails ill get the D5 version of this res.
I'd just get the D5 straight off tbh. It'll just be a massive hassle to drain the loop to put in the new res, and even more of a hassle worrying for the next few months about whether it's going to die or not.
Up to you, but I'd be putting my money on it not lasting 4 months.
Yeah but i already have the res combo, so ill try it, ive read reviews of people using it in a multiple set up, so ill suck it and see.
