Ne one come up with issue's between Asus's Pc Probe II and everest?
In another thread i read someone told of issues regarding temp differences
between real temp and everest, so i decided to check mine, running pc probe
and everest at the same time,
First there was a couple of degree's temp difference between the two, which should i rely on?
But then! crazy s**t started happenen, Pc probe alarms went off all over the
shop, the cpu voltage was 42v, cpu fan dropped to 100rpm, dram voltage
dropped to 0.05v pll voltage dropped to 0.15v,
All these things happened only for a second, and one after another, (not at the same time)
I then closed everest n left probe open for a while n nothin went wrong
except the south bridge temp hit 255C for a split second, must be a
false reading, it hit 255 and then straight back to 48 with in half a second,
I'm guessing it was a software conflict betwee the two programs,,,
or that pc probe is just crap,
I'd say the processor would blow up instantly with that many volts runnin
thru it,
Help????
thru it,
Help????
