CPUZ Thread
Pc:
CPU: Intel Core I7 4930k @4.4ghz 1.232v
CPU cooler: Cooler Master V8 GTS
RAM: Corsair Vengeance LP Black 8x8gb ddr3-1866mhz (running 1634mhz because XMP is unstable with my OC)
Mainboard: Asus P9X79 Pro
GPU: Dual Gigabyte Geforce GTX 780ti reference cooler running at 1219mhz boosted
Case: Fractal Design XL R2
Monitors: 3x Eizo Foris FS2333 on a XFX triple monitor stand
OS disk: 2x Samsung 840 Pro 256gb in raid0
Media disk: 1x Samsung 840 Evo 1tb
Backup disk: 1x Western Digital Green 3.5" 2tb
My Gaming Rig :
Cpu : Intel Core i5 4670k
Ram : 1x8gb Kingston Hyper-x Black 1600mhz
Mobo : Gigabyte Z87-HD3
Psu : Corsair CX600 Builder Series
Gpu : Nvidia Gtx 650 Ti Boost 2gb
Case : Aerocool Strike-X One
Hdd : Western Digital 2tb Caviar Green
intel i7 4770k socket 1150 @ stock with Corsair H100i
gigabyte g1 sniper z87
16gb Crucial Ballistix sport ddr3 1600 @ stock
Zotac GTX 560 Ti Amp!
Corsair RM750
NZXT Phantom 630
Cpuz
i7 4930k @ 4.5GHz - 1.41 Under AIO
GSkill TridentX 2400 @ 2394MHz 1.65v
Asus Rampage IV Extreme
Nvidia GTX690 w/ +132MHz Core & +264MHz VRAM OC
Creative SoundBlaster Z
Seasonic X-1050
Corsair Force GS 240GB + Seagate Barracuda 7200.14 3TB x 2
Corsair Air 540 Cube
All Noctua NF-F12 PWMs w/ Red lightning in the case
CPUZ Validation Link
FX 8320 @ 4Ghz oc
MSI twin frozr iii 7950-1100Mhz/1500Mhz
asus m5a97 evo r 2.0
crucial ballistix sport 8gb 1600Mhz
Kingston 60gb ssd now v-300
WD (blue) 500gb
corsair h80i
cooler master haf xb
Cpu temps 30-50c
Gpu temps 32-71c
Sabertooth
Asus Sabertooth P67 Rev. B3
Intel Core i5-3570K @ 4.6 Ghz - air cooled by a Zalman CNPS-9700 LED
Corsair Vengeance DDR3-1600 , CL9 , XMP , 1.5V , 4 x 2 GB
XFX Radeon HD5870 Standard
CoolerMaster Silent Pro M600
CoolerMaster CM690II Advanced Case , 2 x 140mm and 1 x 120mm fans
Tomi-PC
i7 3770K @ 4.3 GHz - 1.225V - CM Hyper 212+
Kingston HyperX Beast 4x4 GB @ 2400 MHz
Gigabyte Z77X-UD3H
Gigabyte GTX 770 4 GB
Chieftec 750W (CFT-750-14CS)
OCZ Agility 3 120 GB
WD Green 500 GB
Samsung 1 TB
Custom N7 Cooler Master Elite 430 Black (my first "mod", lame pic here)
3x Arctic Cooling F12 fans, a stock, loud and strong CM cpu cooler fan, and a case-front blue led CM fan
Fujitsu Siemens 21,5" 1680x1050 monitor
I'm planning on getting a Corsair C70 and Enermax T.B. Silence Blue Led fans, but first, I'm saving up for a good 1440p monitor :)
My Rig
BitFenix Ghost
i7 3820 @ 4.4ghz
G.Skill Ripjaws Z 16gb 2133mhz
Gigabyte X79 UD3
Vertex 4 128gb SSD
2TB Seagate Barracuda
Corsair AX750
H100i
2 x Sapphire 7950 in Crossfire
CPU Z Validation
http://valid.canardpc.com/80ay7b
Keep up the good work everyone :) Best forum and Youtube channels for hobbyists on the net I think.
Intel core-i7 4930K @ 4.5 GHz 1.405V
EK Supremacy, custom loop w/ 5 x 120 x 45 mm surface area
4 x 4 GB G.Skill RipjawsZ 1600 MHz 9-9-9-24 @ 1666 MHz 10-10-10-26
Gigabyte GeForce GTX 780
Corsair AX1200i
CM Storm Stryker with TTL-roof mod!
Asus Xonar D2X
AKG K701
2 x Corsair Force GT 120 GB
2 x Seagate Barracuda 2 TB in RAID 0 for 120 fps game capture
1 x Seagate Barracuda 1 TB
1 x external WD Green 1.5 TB
1 x external Intenso cheapo drive 500 GB
Saw the post on Facebook so thought I'd drop it in here too.
2500K 1.48v @ 4.8ghz Watercooled with triple rad, 60mm depth, I can't recall the waterblock I used, temps are not an issue, 69degs after 1hr of OCCT.
Silverstone TJ-07 case
4x4gb Corsair Ram 1600mhz 8-9-9-27 2T 1.5v - I really wanted to run the ram faster at slacker timings, I think using 4 DIMMS make this just a pipedream, but I recall struggling to get more bandwidth when I only had 8GB in there also.
120GB Mushkin SSD OS drive, 240GB Samsung games drive and a 1TB media drive
4GB 770GTX Palit GPU
SoundBlaster XFi Music PCI Sound card.
http://valid.canardpc.com/he6l4x
attachment.php
intel i7 4770K @ 4.4
g.skill ripjaws X 8GB @ 1600Mhz
gigabyte GA-Z87x-OC
samsung 840 pro 128GB SSD
four hard drives (various sizes, trying to get money together for a small home server)
corsair cx-600 V3 PSU
EVGA GTX 7709 dual SC 2GB
custom waterloop
coolermaster haf 932
This is my main gaming rig, no overclock at the minute.
CPU: AMD FX-8350
Motherboard: Gigabyte GA-990FXA-UD5
Memory: 16GB Corsair DDR3-1333
GFX: Sapphire HD 7950 Vapor-X OC Boost
SSD: Samsung 840 250GB
HDDs: Western Digital Caviar Green 2TB (x2)
CPU Cooler: Cooler Master Hyper 212 Evo
PSU: Corsair AX760
Case: Fractal Design Define R4
Figured I'd post up my secondary rig, only just threw it together yesterday reviving old parts off the shelf.
This hasn't an overclock either, but rather an undervolt of 100mV and as a result the stock cooler paired with the 955 (the one that came with the FX-8350 that is) is surprizingly quiet.
CPU: AMD Phenom II X4 955
Motherboard: Gigabyte GA-MA790FXT-UD5P
Memory: 4GB Corsair DDR3-1333MHz ValueSelect
GFX: MSi GTX 560 Twin Frozr II
HDD 1: Western Digital Caviar Black 750GB
HDD 2: Western Digital Caviar Green 1TB
CPU Cooler: FX-8350 Stock Cooler
PSU: Corsair HX620
Case: Cooler Master Centurion 590
http://valid.canardpc.com/4gq6e3
The things you can do when your boilers broke in your house :lol:
but yeah, this chip does 4.8ghz at 1.28........but cant keep 2133mhz ram :mad:
Here is mine from when I was pushing it on water, could probably get more out of it if I really looked in the bios settings and had better cooling.
Temps maxed out when benching at around 82c under a 480mm and 360mm rad with the motherboard and my old 680's watercooled.
http://valid.canardpc.com/2895979
The Slug
Phenom II 1090T @ 4.4GHz - Custom Loop
GSkill Snipers 8 GB @ (near) stock
Asus Crosshair V Formula Z - CPU 370 Block
2 X Asus Radeon Direct CUII 6850 - XSPC Raystorm Universal Blocks
Onboard Sound
Corsair AX 1200
OCZ Vertex II 120 GB SSD (OS) - Samsung 1TB Games/Media HDD X 2
Coolermaster HafX
Full Custom Loop
http://valid.canardpc.com/www9bt
See above
A little update for me, bumped up the multi from 20 to 21 and the vcore to 1.3125V. It is perfectly stable and tested with 1 hour of OCCT and stayed below 60 degrees. It looks like it also fixed the issue I had where it didn't boot sometimes, guess X58 does prefer odd multis in the end :)
maniac's OC"3"D rig - Rig Gallery Here
NZXT Switch 810 White
Intel Core i7 950 @ 4GHz
Asus P6T
G.Skill Pi Series 1600Mhz 6GB
2 x EVGA GTX580's in Sli w/ Backplates
Asus Xonar DG Soundcard
Corsair H110
Corsair HX850 V2
Intel 520 120GB SSD
Seagate Barracuda 500GB for Games
Western Digital Green 2TB for Storage
Project - Hulk
Hulk - custom Corsair Air 540 (not fully done yet...soon)
i5 - 4670k @ 4.5Ghz - 1.29v
Patriot Viper DDR 3 1866mhz @ 2000mhz 1.5v
Gigabyte Sniper M5
EVGA Hydro Copper 780 GT Classified
Koolance 380i cpu block
Seasonic 860watt PSU
Intel 530 240gb SSD
500gb WD Raptor
CPU - Z Validation
GPU - Z Validation
