CPU's Revisited - A great article for you younger guys...
name='FragTek' said:
The Overdrives were wierd... I forgot what it was but something else in ur comp limited which Overdrive u could get. I remember they had a 166mhz Overdrive and I couldn't get it because it wasn't compatible for one reason or another. I think it had to do with the chipset but they called it something else.
Take you back....http://cpu-museum.de/?m=Intel&f=Overdrive+CPUs
it wasnt something to do with the voltage was it?
The AMD K6-2 - the first machine i picked all the parts for and built totally myself.
And the chip i spend £600 on the day it was released (ouch)
ow! musta hurt
i have an old overdrive lyin round i fink the prob was summit to do wit the chipset/voltage (i forget so so long ago)
sai_jao said:
ow! musta hurt
It only hurt when i was trying to remove the stock intel heatsink on day, slipped with my screwdriver and fucked it up.......
I repeatedly hit my head against the wall...
ouch . take it that it 'arrivied that way'? or did they not buy it , wat did u do
:banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
I can't remember what the compatibility prob was with the Overdrive but it didnt seem like voltage however that might have been it.
the first pc i had and still have my sis uses it for freecell!!
Specs
133mhz p1 socket
16mb ram
1.8gb hdd
win95!
a printer stll in godd condition and still used I.E. a hp690c and an AOC scanner the width of a case thisckness
my first p.c was a 20MHz ibm one that we ended up giving away, then my first proper one was a AMD Athlon 1GHz with 128mb of ram, and a geforce 2 with a 28.6 gig hard drive, and a dvd burner...i got that in 1999
My first Puter was genuine IBM 16 mph and 4 meg of ram one of which was kept in place with a wood chip on account of a breakage and came with MCI slots - a real bummer as of course these were expensive and not readily available as the vesa and pci slots were. I never got around to getting the maths co cpu. This IBM cost around £1800 circa 1989 -a fortune, and would not even run Windows with any degree of stability or indeed usefulnesss. Brings back memories of DOS now just a distant memory
