Resonance
So, this is just a quick little question...
I've always used the CPU temp to gauge the temp of my CPU, but i've been seeing many people using the cpu core temp to gauge it.
I use cpuid hardware monitor and aisuite to reference the cpu temps, which i think are a bit high, around 39-41c just moderately using my pc. although, the cpu core temps are around 26c. should i use core temps as a reference or cpu temp? (i know fx processors get hot)
other info:
vcore at 1.32v
4.4ghz
h100 in push only, at 2.1k rpm
other info:
vcore at 1.32v
4.4ghz
