Hey All.
I built my PC about 5 Years ago. The specs were as follows -
Asus M5A97 Pro Motherboard
AMD FX-4100 CPU
8GB 2X4GB 1600mhz G.Skills Ripjaws
Powercool 650W PSU
Sapphire HD6770 1GB
Seagate 7200RPM HDD 500GB & 2TB
All in a Coolermaster HAF922 case
Recently I have added/ replaced the following -
Added 2X4GB 1600mhz G.Skills Ripjaws (16GB total)
Added Samsung 650 Evo 120GB SSD
Replaced GPU with Asus R9 290 4GB
Replace PSU with HX750i
Added H80i GT
I have changed most of it except the CPU & Motherboard. But I want to go Intel. But I'm not sure what CPU will suite me. I am looking at the Maximus Hero VII for the motherboard. I play games obviously but I also use Adobe Premire pro and after effects a bit and hopefully will a bit more. I don't use it too seriously but I need some help deciding what CPU would be best. I Want good Value but don't need to be a cheapo
I also intend to build it into a Corsair 750D.
Thanks for help
Ally
AMD FX-4100 CPU
Powercool 650W PSU
Sapphire HD6770 1GB
Added H80i GT
Thanks for help
Ally
