I have a question to ask anyone that is willing to answer! What CPU cooler do you think would be optimal for looks, performance is an after thought, in my build located here.
I was thinking the same thing, the only problem being the color of the casing of the fans. This is why I am asking, so I get opinions on something like would the white throw off the the cases scheme.
You hate it! I think it is fantastic, but it is just one of those cases. Also, I should say that I am custom creating my cables to fit the color scheme of my system. White could work with that.
I can already spot a possible problem: that CPU connector.
Since I don't see a gap to guide it through at the top of the motherboard, I think an extension will be needed. (Since it's practically on top of the stock cooler now and it just doesn't seem long enough to be guided round the top of the board.)
Anyway, a Phanteks PH-TC14PE Blue/White would suite it perfectly, if not take a look at the NZXT Havik, they're both fantastic looking and both great coolers.
Actually Mr. TTL himself solved this for me. I had a couple ideas of how to get around this, but didn't even thank to route the cord behind the motherboard, which I can. So it shouldn't be a problem, route the cord behind the motherboard and it looks wonderful. Oh and there is a bit of a gap at the top of the motherboard, just not a cutout.
