Mick.T.Phallus
I'm building a computer and having mad ball ache with the screws on the xspc raystorm cpu block the screws are too thick. I've been filing them but can only get the tip screwed into the backplate and on an angle but soon as I started tightening the second bolt down they spring up! Is this normal for these? There's 2 lots of screws one without an head and one with which I'm using, the ones without an head are even thicker. Would have been a whole lot easier if the friggin screws fit, was looking forward to this build, I'm now getting that homesick feeling for air cooling
First watercooling attempt too much money spent to fck it up!
cheers
cheers
