Couple questions...
| raVen |
Hey people
I was planning my next build in next 3-4 months, but it will come in the end of the next month
I will be using white NZXT 810.
And the main question is....... should I go for white cables(bitfenix alchemy)and blue lights, and white coolant?Or for white coolant, blue cables and blue lights, or for white coolant green cables and mix blue with green lights???Whats the best option?
I will be using my current motherboard, 7970 with EK fullcover water block, Alphacool NexXxoS UT60 360 with Scythe Gentle Typhoon 1850rpm, push-pull + phobya 240 G-changer with the same fans with push pull as well. Laing DDC Ultra, bitspower fittings, phobya balancer 150 black nickel(or go for XSPC 5.25" Dual Drive Bay Reservoir?), also this time I will mount DDC right above the top fans from 240 rad, so this time pump shouldnt burnd, anyway I will buy koolance DDC pump heatsink.
So what you think about that???
in the end its all personal preference but I'd like to see white with green cables and lights
The thing is that I already have green alchemy cables so will be cheaper, also have a lot of green lights, but green looks better with black, and blue looks better with white
