In the Nvidia Control Panel select the menu "Set Multi-GPU Configuration". You will have two options. To disable SLI select "Multi Display Mode" for SLI select "Multi-GPU mode".
A restart is required if you go from Multi-display to Multi-GPU, but not the other way.
