Cosmos S HELP
MAdion
[font=verdana, arial, helvetica, sans-serif]How on earth do I take off the plastic edging on the Cosmos S, I can take pull up the tabs but there is something stopping it on the corners, anyone got any ideas of what is in the corners. Then I could finally start my build.[/font]
I meant.. Use google to show a picture of your case, then explain what you would like so someone more professional can give you advice*
