Corsair White 600 T on water
ilidaan
Hi
I reacently finish build up my rig, so i wana share with you forum members....
Spec:
Rampage III Extreme
Intel i7 960
Corsiar Dominator GT 12 GB / 1866
2 x Asus GeForce 560 Ti TOP
Corsair AX860i
Creative Fatality SC PCIEx
Kingston Hyper X SSD 128 GB
2 x 500 GB WD in raid 0
1x 320 GB WD
Water cooling components:
DDC pump with res combo 140 mm
3 x EK XTX 120 Rad
1 x Stealt GT 120 Rad
HF Supreme CPU Block
2 x GPU HF Supreme bridge edition blocks
1 X EK Parallel Link
ClearFlex Tubing 12mm
EK Fitings
EK Ekoolant Blood RED
6 x Scythe Gentle Typhoon AP-15
Pics:
Clear side panel with 140 mm fan:
Clear side panel with Skyrim logo:
Interior:
Hope u like it :rolleyes:
Im no WC expert but that looks like a lot of cooling on little rad area.
Looks wise it looks pretty decent, but those 120mm rads.. not a fan.
I like the SSD mounting, new side panel and the res setup you have going but for the love of all things cooling, you have at least 2-3 120mm rads that you just don't need. A 60mm thick 240mm radiator(or maybe 80mm, not sure with the 600T) would have worked out much better for you and probably been cheaper and easier to install as well. You could also have used a 240mm rad up top as well instead of the 2x120, roughly the same amount of cooling and the ability to use an extra exhaust fan at the back.
The general colour concept is good too as your choice of components has complimented it.
Just my 2p
Thats a nice case there matey, what temps are you getting and are you overclocking ? That 960 should easy do 4.2 on water 24/7 .. Also if you take the 24 pin out of the hole just above the one where it is now it would be a bit neater in my opinion..
Nice to see old hardware still going strong and looking great :)
As said above it could have been alot better just by having a 2 240mm radiators ( if it would fit) still looks quite nice though mate :)
Looks amazing, I'm not so sure about the fan on the side window though so I would use the other window.
Good job anyway :)
120 rad at top dont look right you should of gone for a 240 also not to keen on the wifi arial, colour scheme is good and side pannel
Everything is amazing except dragon on glass but that is personal taste...
That is Gentle paint in black??? Uhhh that is pain... I destroy one fan because of that.... I mean he working but he is not centred any more... I don't know how other work good...But never mind I need different (GT AP-45 model) any way.
He became AP-14, AP-15 and AP-45 on 650D fan controller depending on (low-mid-high)
Yes the CPU is overclocked to 4.0 . The temps of the CPU at full load with prime 95 are around 60 - 63 C at idile 30 - 33 C. The graphic card are allready factory oc, with furmark 52 C at idile 28 -30. The mobo is the best. Wen it was cooled with original heatsink the idile temps was around 60 -65 C, at load 70 -76. Now with waterblock on it te idile temps are 30 -33 and at full load the max temp i ever saw was 47. :) oh the ambient tems was around 24 -26 C...
Yes they are gentle paintet in black, and yes i am aware of this problem of destroying a fan because of paint. I use realy god paint ( paint + hardener) and spray- it evenly only 40 microns with special painting pistol in my company where i work.
PS: Lijepo je vidjeti da je još neko na ovom forumu iz stare Juge.... :)
I thought to paint mine with same color like CORSAIR paint their fans for H70 and H50 example, some texture mat black. I can't find that and I will leave next like fabric because little difference. If everything is dark can became little...
I see that is good painting on fan frame... I search little ring two times at home, one almost 3h on necks on floor with magnifier...I try to remove and suddenly no ring, he jump somehow over my head...Lucky I don't have nothing on floor.
Next time I push whole head and hands and fan in one naylon beg and remove rings from Gentle Typhoon, from what... No more...
Where you bought yours???
Just my 2p
Why o why u think that the 240 rad is better performing than 2 x 120 in serial. U have the same cooling surface and allmost the same volume for liqud. All 120 rads from EK are 65 mil thick, so i have 360 rad 65 mil thick in that case + 120 stealt GT rad with a very fine mesh, 30 mil thick. All rads are conected in serial so the loop goes from the res to pump then through all rads to cpu, mb block, gpu and back to res. Why i chose 120 rads.. Well if u insert in the front 240 mil rad u lose a one 5.25bay at the bottom drive bays, because of outlets from that rad. If u put 2 x 120 rad and conected to serial u have all four 5.25 bays available. If u saw the last picture a need all four drive bays. You're right 240 rad is cheaper than 2 x 120, but cooling performance is about the same and i get some extra space.....
That just looks horrible to me :/
Even though I respect your reasoning why you choose to go this way.. and you're a fellow 600t white owner, I'd still rather have air cooling than make the inside of my case look like that.
I just love !! the window cut though. Did you order this or made yourself?
Yes i made the side panels by my self :)
It's a look that DEFINITELY takes some getting used to, but the more I look at it the more I like it. I have the gunmetal version of this case and I love seeing new things being done with it. took me a sec to figure out what you did with the rads in the front, but that actually makes a lot of sense to mount them like you did. I also like the interchangeable panels, nice touch. Pretty nice temps as well, great job!
