Corsair H80/H100 dissected?
PlayingWithAndi
Hello, I was wondering if there are pictures on the internet of the H80, H80i, H100 or H100i disassembled. I would specifically love to see the CPU block's cooling fins.
Thanks.
Unfortunately, I don't think you'll find anything since if you take the block apart, your cooler will be unusable. The whole point of those units is maintenance free liquid cooling so if you take it apart, it's no longer maintenance free because you'll have to worry about leaks, coolant levels, possible algae growth, replacing coolant, etc.
Here you go, the h80/100 is the same block/pump wise but this is from a h100 if that matters.
@Crion They actualy just clip/screw on/off with a little work, im 99% sure thats how they fill them. as they are the only part of the loop that it wouldnt be a pain to do it from.
