Corsair H105 pump cable
Lozi
I'm at the point in my build where I am fitting my h105 and I'm a little confused.
Is it ok if I plug the 2 radiator fans to CPU_FAN with a splitter and connect the pump to CPU_OPT?
It's normally the other way round, Pump to CPU_FAN at 100% in the bios, Fans connect to any other available 3/4 pin fan header with the included fan splitter.
My confusion is can I use the CPU_OPT, is this classed as a fan header?
I'm new to it all and still trying to get my head round it, I'm sat building it now
It is classed as a CPU optional fan header. So yes you can use it, just be sure that the pump is set via which ever header it's on at 100% in the bios, better still you could always go 3 pin to molex for a better 12v feed.
