So because of massive workload we have done this review a little differently, its just the video but it is embedded on the competition page too.
https://www.youtube.com/watch?v=V5OmcQxhP24
I did notice![]()
Are you not a fan (lolpun) of it? I don't have positive pressure in my case either but that's due to aesthetic reasons - if I put the rear fan in the other way round I'd see the ugly side of my fan.
Its just that on other forums i've read that more exhaust fans than intake is better, but now i changed my opinion
Oh, I was massively surprised when that got a gold award. To me it seems so far behind the 250D and 350D that its pointless. To basically only be able to fit an mATX board, one radiator and a fan and then be restricted very badly on graphics cards width. And as an ITX rig it's not going to hold much more than a 250D maybe if you really tried hard you could waterblock the GPU and fit two 240's but that's not exactly a massive increase on the 250D. It doesn't look as good (IMO), has no dust filters, IO is messy, couldn't take an optical drive if you wanted to, can't really fit anything above the motherboard and has no room for graphics cards. It's gotta be a lot cheaper than the 250D to be rated as highly.
If it was 30-50mm taller/wider so all GPU's could fit and fans/radiators would sit above the motherboard then I would agree with what you say. It seems to me like the bottom/left hand side is there purely to match the other side and serves no function which is really wasted as it could if the case was just a bit taller. Which it needs to be to fit DCii's and Classy's, probably the DD and any cooler rocking girth. But anyway it's supposed to be an 'air' case so erm put a DH-14 in there or is it going to have the heatpipes holding the window up.
JR
